Wire Interference (?)
Old Mar 25, 2004
stupidd's Avatar
stupidd is on a distinguished road
I've been messing around with my system a lot lately. I've got cd player, in dash tv, amp and sub.
it bumps (feedbackish sound) everytime i switch sorces, turn the volume to zero, turn it off, etc. I watched the subwoofer and it actually flexes all the way out! not like quick but kinda slower than a hit. (solo baric 10' L5).
I've got RCA's running from HU to the amp in the trunk next to the power wire.
HU ---->RCA--->Amp--->Sub
I've got a bout a million wires behind the HU and tv, is it possible that certain wires close together can mess each other up? Could this be why my subwoofer is doing this? cause i do have video wires as well for the tv behind there.
i also tried something different. I unhooked one of the rear 6x9s and connected that wire to an RCA converter, then to the amp and it works fine. no problems.
HU--->Rear 6x9's--->RCA converter--->RCA--->AMP--->Sub
Old Mar 26, 2004
stupidd's Avatar
come on. are there any common do's and don'ts when it comes to running wires? Like dont run RCA's next to power?
Old Mar 26, 2004
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
what kind of head unit do you have?
Old Mar 26, 2004
stupidd's Avatar
Pioneer DVH - P5000MP
Old Mar 28, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
Re: Wire Interference (?)
Never run signal and power wire next to each other unless absolutely necessary, that is rule #1. Also, the turn-on/turn-off thump is from a your different sources powering on/off at different times. If the amp is on before the head unit turns on= thump. Use a relay off the acc circuit of the car to daisy chain the aftermarket equipment as necessary. Cheap components can also cause unwanted noise. Good luck!
Old Mar 28, 2004
stupidd's Avatar
first i'll try moving the power and rca's. i really do hope that works. next i guess i'm shootin for relay...
so will a relay delay the signal going to the amp? if i were to look for one on ebay or at a local electronic store what am i looking for?
thanks for the help!
Old Apr 2, 2004
stupidd's Avatar
can I use that big bar behind the HU as a grounding point?
Old Apr 3, 2004
WhiteRabbit's Avatar
http://www.digitalww.com/DVD_DV_8680.htm
youll have to call the guy to ask if it does VCD's
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
