SRS light
Old Jan 16, 2004
mrb420's Avatar
mrb420 is an unknown quantity at this point
Lightbulb SRS light
whats up everybody,
so i was running the wires for my amp last night.
i removed the driver and passenger seats to get under the carpet.
when i put them back i made sure to attach the connections under
each seat, but when i started my car the
SRS light came on. now it stays on.
could a blown fuse cause this problem?
i checked the SRS fuse and it seems fine.
could it be linked to another fuse?
the book says to have the dealer check it, but i don't
want to do that cause it will probably cost alot,
and they might say i caused it by running the amp wires.
could that void my extended warranty?
any suggestions...
Old Jan 16, 2004
HondaLuver's Avatar
Its a celebration bitches!
welcome newbie, but we have 2 things to solve this problem for you,
1. the search button
2. we have a DIY(do it your fuc king self) to reset the light.
Just because ur learning, i'll give you the Link
ibtl(in befor the lock)
Old Jan 16, 2004
mrb420's Avatar
thanks for not being too hard on the new guy.
i found the DYI.
Old Jan 16, 2004
alex053's Avatar
question...im gettin some sparcos...any way to fool the car into thinking that there is a factory seat there so that the light isnt always on?
Old Jan 17, 2004
HondaLuver's Avatar
humm, i think the only way you can trick the car to think there is a seat there is to compleate the circut... there are 2 cables aside from side impact bags. one for the seat belt and the other for a senor that senses if there is a person on the seat.
Old Jan 17, 2004
alex053's Avatar
pretty sure its just grounded..ill mess with it when the time comes.
Old Jan 17, 2004
civic01vtec's Avatar
hmmmm........
Old Jan 18, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
yeah i took my seatbelts and everything out so my light stays on all the time is there any way you could wire it so that the light goes off because there is nothing to connect it to thanks for the help
Old Jan 19, 2004
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
well you could always take the bulb out.....
Old Jan 19, 2004
how do you take the bulb out
Old Jan 19, 2004
go to the diy section look for the installing indigo gauges follow that to get the cluster out, then just find the corrisponding (sp) bulb and take it out
Old Jan 20, 2004
mrb420's Avatar
Just to keep you guys up to date, I followed the DYI using a paper clip and the help of my lovely lady, and reset the SRS light on the fisrt try.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
