View Poll Results: Which AMP would you get?
Orion 8002
37.50%
JL Audio 500/1
25.00%
MTX 801D
6.25%
Alpine MRD-M500
31.25%
Voters: 16. You may not vote on this poll
**POLL - help SkipBarber
A descendant of 2k1civic.com
I'm posting this for SkipBarber. He can't do the polls so I'm doing one for him. He just picked up a subwoofer for his car, so he's looking for an amplifier now to push this bad boy. . Soo. . here is what he has.
1 12" Alpine Type R Sub. 4ohm DVC (8ohms total)
The specs:
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Bumped Backplate
Compound Radius Curve Pole Geometry
Custom Cast Aluminum Frame with Integrated Heat Transfer Plate
Designed and Engineered in the USA
Dual Progressive Oversized Nomex® Spiders
Dual Stacked Magnets
Dual Voice Coil Design
Extra Length Extended Pole
Flared Pole Vent
Heavy Duty 8ga. Push Terminals
High Excursion 1" Santoprene Surround
High Strength Brass Voice Coil Bobbin
Integrated Tinsel Lead Design
Kevlar Reinforced Pulp Cone
Magnetically Optimized Motor Structure (Pat. Pend.)
Oversized Parabolic Dustcap
So from the list below. . You can click on these amps and see which one you recommend for him, then help us out by voting in the poll above!!
Which amp is the best choice for him?
Orion 8002
JL Audio 500/1
MTX 801 D
Alpine MRD-M500
The specs:
Bumped Backplate
Flared Pole Vent
Orion 8002
JL Audio 500/1
MTX 801 D
Alpine MRD-M500
yea, thanks dude, i was really looking at the JL and alpine amps. at work we already hooked it up to a JL 500/1 amp and hit hard...so...i dunno. im torn between them. anyone own either of these amps? tell me what you think.
Originally posted by LudlamTheory
no such thing as overkill my friend...
its a toss up between teh m500 and 500/1
the 500/1 would be pricier
i boogie for the raindrops
Originally posted by Bogus1
You can always run it at 8ohms,
IMO just buy another sub and bridge it
man the "onion" is killing them out there...
i said alpine:
1) it's a nice amp power wise
2) it's not ugly looking, kinda sharp IMO
3) has a pretty small footprint
4) show wise, it's matching equipment
i said alpine:
I would go for the Alpine MDR-500 only if your sub could be run at 2 ohms. If not, you are going to be only running 250 rms. I got the Alpine and it is very nice, especially if you get the RUX-4280 Remote control. The remote allows you to control all the amplifier’s setting right from the driver’s seat.
skipbarber
Engine Swaps
Feb 16, 2010 02:00 PM
skipbarber
Sep 1, 2007 04:40 AM
