Skipbarber's boost story. Latest dyno numbers..
Old Mar 8, 2009
skipbarber's Avatar
It's been 2 years since I last dynoed and tuned my car. The first time was with my first boost setup. Which yielded expected results. At the time the mods were:
Bone stock D17a1 non vtec
Dezod EL manifold
T3 super 60 garrett turbo
SF charge pipes and FMIC
RSX-S injectors
Greddy Emanage full setup with boost sensor
Greddy profec boost control (although I was running wastegate spring pressure)
Tial wastegate
HKS SSQV
Removed cat and greddy exhaust
with this setup it produced just shy of 170 fwhp and 141 ft/tq
the dyno graph REALLY shows the limitation of the stock cam, you can clearly see where it was meant to be shifted.
Anyways, it was great for a while, finally blew a headgasket because of the emanagles inability to be reliable, not only that but I got tired of constantly trying to avoid part throttle boost. Shortly after, due to an oil leak i wasnt ever able to figure out, I spun a bearing.
I suppose this is where it escalated. I bought a junkyard motor, another D17a1 and a vtec head. I wanted to keep the lower compression non-vtec pistons, which is why i didnt go out and buy an A2 to begin with. I rebuilt the new motor to stock specs, again using an entirely stock bottom end, ARP head studs and dropped the VTEC head on with crower valve springs and retainers, new seals and a crower stage 2 boost cam.
while I was at it I picked up a Hondata Kpro and did my return fuel conversion with an aeromotive FPR and walbro fuel pump. At this point I decided that it was a good idea to keep a good thing going, so I also invested in an exedy flywheel and stage 1 clutch. Dropped it all back in. Over the past year ive been tweaking things here and there, doing some street tuning, reworking some existing components.
Added RDX 410cc injectors in place of my RSXS 310cc injectors, rewired my primary o2 sensor to a stock wideband setup to make tuning from the Kpro easy. Dropped in a new turbo (same specs, just new) and fitted it with a V-band and a much better made DP. Most recently my stock radiator sprung a leak, so I got a koyo and fitted the slim fans I already had.
Finally over the weekend a local crew was having a drive and dyno day. During the day i did as much street tuning as i could, datalogged everything and set my boost and fuel figures to perfection as much as I could before throwing it on the dyno. so without further ado:
MOST CURRENT SETUP (THIS IS TO AVOID PM's) IF YOU DON'T SEE IT, I DON'T HAVE IT.
Acura RDX 410cc injectors w/scion tC plugs
SF intercooler/custom pipes
T3 super 60 .48 a/r
HONDATA KPRO w/AEM tru-time cam gear
Defi Boost gauge
hks ssqv bov
Tial 38mm blue wastegate w/.4BAR spring
Custom SS open dump tube
Denso Iridium IK20's
AEM wideband a/f gauge
Golden Eagle Vacuum manifold
Golden Eagle Oil feed plate
Golden Eagle blue oil cap LOLZ
Dezod EL manifold jet-hot coated sterling
Custom Upper radiator hose re-route
Custom 2.5" Downpipe
Customized Moroso vented oil catch can
Vtec head swap w/custom oem solenoid and pressure switch wiring
Crower Titanium springs and retainers
ARP head studs
Exedy Stage 1 clutch
Exedy lightened flywheel
Crower stage 2 turbo cam
Slim line fans
Aeromotive FPR
Walbro 255lph HP in tank pump
OEM wideband primary o2 to AFR sensor conversion
Greddy Evo 2 cat back
Koyo racing aluminum radiator
I was expecting 220 at most..
240 whp and 209 ft/lb tq just shy of 9.5 psi keeping my AFR's considerably rich, roughly 10.5-11 AFR under any boost. I couldve easily gotten more power from leaning it out a tad bit across the range, but considering Im running a stock bottom end, Im playing it safe. at full tilt 1st and 2nd gear are useless. and my already upgraded 11" front rotors have a hard time stopping me.
Things to consider: I am an ASE certified mechanic. I am confident in my engine building and tuning abilities. I have taken the required steps to ensure proper and safe operation of my motor. Do not attempt to tune your own car if you don't know how. Never boost a car and drive it hard without a proper tune. I will not share my tune with anyone so do not ask for it.
Old Mar 8, 2009
speedfoos's Avatar
Re: Skipbarber's boost story. Latest dyno numbers..
Hey Edwin, can I have your tune and could you PM me your mod list?
Old Mar 8, 2009
skipbarber's Avatar
anything for you clint. If you were anyone else, youd get a PM of FAIL.
Old Mar 8, 2009
good stuff
Old Mar 8, 2009
D5cIvIc's Avatar
Can i have your tune? i want to have a base map for my k motor?
JK!
Old Mar 9, 2009
speedfoos's Avatar
Honestly though, I would bump it to 11.5 - 11.75 under boost so you're not running the risk of fouling things out from such a rich exhaust stream coming out. You'd get a little better gas mileage and since you have kpro anyway, futzing with the timing is your key to operating without detonation. IDK, I'm sure you've thought about it, but 10.5 -11 is way too rich for my girl. And I like my girls like I like my cars, a little rich and a little retarded.
Old Mar 9, 2009
skipbarber's Avatar
spoken like a true man-*****. I will lean it out a tad, it's because it was a 70 degree day. it's been 40 degrees all week, then suddenly it felt like summer. in the colder weather it wasnt running that rich.
Old Mar 9, 2009
drunkenmagnum's Avatar
good numbers there, nice to see it made decent power!
Old Mar 9, 2009
do you have different tunes for winter and summer?
Old Mar 9, 2009
dezod's Avatar
7thgen Power Maker
Nice!
Old Mar 9, 2009
skipbarber's Avatar
no. but the numbers change based on weather pretty easily.
Old Mar 10, 2009
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
awesome i cant wait to see my numbers. I have the best emanage tuner in the area, lets see his magic
Old Mar 10, 2009
I know this has been asked ubt is there any thing special to running the RDX injectors as far as making additional modifications? I have SRT-4 injectors and I am still running a little lean. Reacently upgraded the fuel pump and might go with the RDX units if it is worth it.
Old Mar 10, 2009
ronaldo9's Avatar
What are you using to tune? Sorry to thread jack maybe start a new thread stating your problems Drunkenmagnum.
Old Mar 10, 2009
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
kpro
Old Mar 10, 2009
Boilermaker1's Avatar
Jap-Euro Fusion
If you're running SRT-4 560whatever CC injectors, and running lean, why would you want 410s from an RDX?
I'd start by looking at the tune. If you have no more injector duty, then get some 680s or 750s.
Old Mar 10, 2009
skipbarber's Avatar
vids coming shortly. car is down for the week, busted the downpipe causing the AFR to read lean and running rich as all hell. I also forgot my thanks.
Clint, Justin, Andy, Rob, the whole Mid-A 7thgen family and a few other members from this forum that have come and gone over the years. More than anything, when it comes to boosting a D17, you need moral support.
Old Mar 10, 2009
speedfoos's Avatar
No probs Edwin, it goes both ways man. Ya'll helped out immensely during my build as well.
As far as SRT-4 injectors, they're only 430cc at stock Honda (43psi) fuel pressure and don't reach 577cc until you up the pressure to stock SRT-4 which is around 53psi.
Old Mar 10, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
NICE Edwin!!!!
mad props on those numbers!
I tried to rep you but it won't let me stupid site
Old Mar 10, 2009
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
good to hear the vic is still going strong!
Old Mar 11, 2009
skipbarber's Avatar
thanks guys.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
WWJD
Sep 23, 2015 12:56 PM
