FatMat Falling Off!
Old Dec 16, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
FatMat Falling Off!
Hey everyone, about a week ago I opened my trunk and I discovered that the fatmat that I had lined the trunk lid with was falling off. I had the fatmat under the trunk lid for less than a year and the tar had lost all of its adhesiveness. I had to say that I did notice a small difference in the way my sub sounded when the stuff was adhered to my trunk, so I thought it was worth it at the time. I still have alot more fatmat in my closet. If I re-apply it, is there anyway to make sure it stays on there.
Old Dec 16, 2003
Mr.Modify's Avatar
yea alot of people have had trouble with it falling off! maybe like some spray adhesive or something?
Old Dec 16, 2003
LiceLocket's Avatar
LiceLocket is an unknown quantity at this point
did u make sure it was clean before applying fatmat? if that tar sticks to dust, the adhesion is gone (imagine putting baby powder on it!). try some adhesive spray, or u can do what i do; (re)install it on a hot day, when the tar is soft and reforms easily. i dunno how hot it is in texas, but i installed mine in the summer, and right now in the winter in san francisco, it is hard and doesn't reform shape. also, after u install the fatmat, do liek three extra consecutive days of "maintanence" rolling w/ the roller, i did that too.
also make sure that there are no bubbles, and use the rolling tool (or tennis ball) to ensure that maximal surface area of the fatmat is against metal.
instead of matting over the gaps, cut them, then fold it in, so it is like a grip, then put another layer above the gap (i leave it having the holes to access some screws and wiring, but some say to seal those gaps)
i have like 3+ layers of fatmat on my trunk lid (powerful sub in the trunk), and it hasnt' fallen off or anything.
Old Dec 16, 2003
tfnaaf's Avatar
BLDNPSI Mod
Use a heat gun if the material is similar to standard dynomat. I'm not familar with fatmat brand. I use ice guard and spray on stinger brand stuff in upside down positions
Old Dec 16, 2003
KeNsHiN's Avatar
LEVA
off topic..............but what do you have?
Old Dec 17, 2003
LiceLocket's Avatar
Originally posted by NeonImpact
licelocket's I.C.E. is:
American Pro 600W by 2 amp
10in diamond audio subwoofer (350W)
stock everything
this is outdated. i have currently:
ppi pcx 1500 amp (1000Wx1)
ppi 440 something amp(100Wx4)
diamond tdx 12 inch sub (1000W rms)
diamond hex components (two pairs)
alpine 9813 deck
two caps
and my trunk lid is fatmatted. how is that off topic?
Old Dec 17, 2003
LiceLocket's Avatar
subwoofer
Name:	diamond audio tdx 12.jpg
Old Dec 17, 2003
LiceLocket's Avatar
setup (flush cover removed)
Name:	full view 1.jpg
Old Dec 17, 2003
LiceLocket's Avatar
fatmat trunk lid
Old Dec 17, 2003
LiceLocket's Avatar
flush covered
Name:	covered flush view.jpg
Old Dec 17, 2003
Fatmat is a joke. I found that out when I got a hoodliner and it fell off in two weeks. Get dynamat extreme. I've had it in the trunk for many monthst and it will NEVER come off. Makes a good bit of difference in sound.
Old Dec 17, 2003
tfnaaf's Avatar
BLDNPSI Mod
I do have to say ice guard DOSEN'T work well upside down. BUT! for the price and it DOES work well. I use it on all other horizontal and vertical areas. Those who say it smells
Old Dec 17, 2003
LiceLocket's Avatar
that doesn't make sense; how can u compare a hoodliner w/ a deadener u put on teh trunk? they're not the same, and they aren't put under the same conditions
Old Dec 17, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Another good way if your applying it in the cold is to use one of those small portable gas torches to heat it after you apply it. Using spray adhesive will make it stick, but will have no deadening properties since it needs to bond directly to metal.
Old Dec 17, 2003
Um, the hoodliner is just a layer of fatmat deadener and foam to put on top of that. It says it was made to withstand extreme heat, but that didn't happen. Oh and the smell is still there after 5 months. I'm glad I never put any inside the car.
curaze
Sep 22, 2015 08:27 AM
mrwhos
Aug 11, 2015 02:03 AM
fecrni
Aug 8, 2015 06:15 PM
Rachels2k1
Jun 27, 2002 05:05 PM
APS
May 22, 2002 08:22 AM
