Sponsored by:
Sponsored by: CARiD
HELP !!! Sideskirt about to fall off !!!!!
Old Jun 26, 2002
Rachels2k1's Avatar
Rachels2k1 is an unknown quantity at this point
Guys, i need your help .. both of my sideskirts, are losing that little sticky stuff that came w/ the wings west g5 kit.. but on the left skirt,the corners are holding it right now, all the sticky stuff fell off and one of the screws is sticking out, thats about to fall off too and its just a matter of time when it'll fall off... I really dont want to be here all day so do you guys know of any product i could buy to help hold it up ? Just for a few days until i take it somewhere to get fixed properly ???? pLeAsE HeLp Me !!!!!!!
Old Jun 26, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
goto home depot.
buy the really sticky double sided tape...
Old Jun 26, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
3m double sided tape will work and last you a long time. Who installed ur kit they certainly did ashaity job
Old Jun 26, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
tighten up the screw. you could try hotglue. get the industrial kind from homedepot
Old Jun 26, 2002
Gryphin's Avatar
00 Hatchback Owner
double sided tape should work if not you can just take them off for now till you go and have them fixed
Old Jun 26, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
Remove your side skirts completely. Go to wal mart and get some 3M adhesive remover and remove all the old dirty tape. Then use some rubbing alcohol to clean both the side skirt and where it attaches to the car. Next apply some new 3M double sided tape onto the side skirt, attach it to the car and put the screws back in. Sometimes it helps if you you let the tape sit out in the sun to activate the adhesive on the tape. Good luck.
Old Jun 26, 2002
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Hello, I had a similar problem with one of my Wings West side skirts. Actually the place that installed them also used 3M tape, screws as well as clear silicone. One of my sides were coming loose so what I did was I went out to buy one of those clamps(vice) and I screwed it to the side of the skirt where it was coming off, than I applied silicone to the hole skirt on the side of the crack. Let it dry for about an hour or 2 and it should be fine.
Old Jun 27, 2002
VTECTypeR's Avatar
All you need is the double-sided tape, they sell it at home Depot.
curaze
Sep 22, 2015 08:27 AM
mrwhos
Aug 11, 2015 02:03 AM
fecrni
Aug 8, 2015 06:15 PM
Aznnp77
Mar 20, 2002 06:26 PM
domesticsnyper
Jan 8, 2002 05:46 PM
