Couple of last second questions
Old Oct 9, 2003
Silver5656's Avatar
Silver5656 is an unknown quantity at this point
ok all the passenger side panels are off....only 2 questions left.....where does the amp power wire go thru the front?.....i took off the panel above the passenger feet, and the panel to the front/right of the feet as well.....what hole does it go thru?.....and where does it come out in the engine compartment?.....also i took off the rear plastics as well....(this is in a sedan)....where should i snake the power wire thru?.....some1 said under the seat....but wouldnt it be easier to snake it thru the hole near the top of the rear seat?.....
Old Oct 9, 2003
Mr.Modify's Avatar
i ran the power wire on the driver side through the firewall hole..but i think you can do it on the left to!! i just found the driver side more convient!!
Old Oct 9, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
there should be a rubber grommet under the carpet, pull it out, and run your wire through there. then pop the grommet back in. least that's how it is in my 01 EX
Bounddyy
19
Jul 20, 2015 02:42 PM
Kyles24
Jul 16, 2015 10:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
1khilari
Jul 9, 2015 08:12 PM
