Can I use trunk starter without 98-02 accord trunk latch?
Old Oct 8, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
If not...what are other options...I just had my trunk latch replaced...I dont really wanna buy another trunk latch. Also, is it easy to wire the alarm to the trunk latch? I don't really wanan screw up my alarm or pay the extra LOT of money to have honda install the trunk option. Thanks
Old Oct 8, 2003
Jaykuai's Avatar
ish...
i placed a trunk popper when i placed my door solenoids (basically the same things) 30usd each ones.. hooked up to alarm..
Done with the stock latch and its VERY simple..
Old Oct 9, 2003
pitciv's Avatar
cool could you tell me where you bought it and how you hooked it up? opening the trunk with completely full hands is a pain in the *** lol
Old Oct 9, 2003
Jaykuai's Avatar
ish...
sure.. i can take a pic later if i dont forget it..
Old Oct 9, 2003
pitciv's Avatar
sweeeet
Old Oct 9, 2003
WhiteRabbit's Avatar
its a solenoid, like a big cylinder with a piston in it, you charge it to 12 volts and it pumps.
so what you do is bolt the solenoid to the structure of the trunk lid to the side of the latch, and hook the cable up to teh latch itsel fso that when it pulses, its basically yanking real hard on the latch.
jay is right, they are totally cheap, you dont need any more than 9 pounds to pop it, most likely you cna get away with far less.
to wire it, you ground one lead to the trunk lid itself, then you snake a wire up the trunklid arm all the way to the relay for the trunk pop alarm output. using a relay is key, it draws too much power to hook to your alarm directly!
its totally a snap tho, there is no hardest part if you know relays real well!
Old Oct 9, 2003
Jaykuai's Avatar
ish...
here it is:
Old Oct 9, 2003
Jaykuai's Avatar
ish...
here is "how" it works..
Old Oct 11, 2003
pitciv's Avatar
Amazing
Where did you get the solenoid from?
Old Oct 11, 2003
you can get them at www.autoloc.com for a very reasonable price
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
SammySC
121
Apr 7, 2017 07:43 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Nalmonte
Sep 28, 2015 01:10 PM
Sep 27, 2015 11:33 AM
