2 questions really... and I'm new to this car stuff.
Old Jul 30, 2003
pj_buddha's Avatar
pj_buddha is an unknown quantity at this point
I have a 2001 Civic EX
1. I'm putting in a KOSS head unit. I'm splicing the wires because nobody around has a harness. I've wired everything properly (I think) to my head unit and it's still not working... Any suggestions on what needs to be rechecked?
2. I did a search... read the posts... and everyone says that it shouldn't be happening.
Well, during my attempt to put in the head unit, my keyless stopped working. What happens is the power locks won't work unless the key is in the on position. If the key is out of on position the power locks don't work and the keyless goes along with that.
Let's just say my car is the only one to have this problem... how would I go about fixing it?
Much obliged
Old Jul 30, 2003
Got Boost???'s Avatar
As stupid as this might sound try turning the headunit on. I got a pioneer for my mazda and i thought the damn thing was broke. Then i figured out that you can turn it on and off, so i turned it on.
Old Jul 30, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
You may get more help (and replies) in the ICE forum for this problem.
Old Jul 30, 2003
civicvtec1ps's Avatar
Search and Learn
you need wireharness....go to circuit city, bestbuy and buy one.
check all the fuses. thats what happened to me.
when i installed my lcd screen.keyless entry . interior lights all those craps didnt work. then i checked fuses , found blown fuses, replaced.every worked after that.
Old Jul 30, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Thats a good point, when I first installed my Alpine HU, I didn't think it worked after I connected it. I had to turn it on first, but luckily everything went fine.
Old Jul 30, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Moved to ICE!
Old Jul 30, 2003
WhiteRabbit's Avatar
gotta be a fuse
Old Jul 31, 2003
seijin_av's Avatar
seijin_av is an unknown quantity at this point
yup, i thinks its a fuse also... i installed my HU and my friend and i just cut everything... and then the powerlocks only worked when the car was on, the dome lights didnt work and the HU didnt work. I'll go take a picture for you right now and circle the fuse i replaced.
Old Jul 31, 2003
seijin_av's Avatar
idk if that worked, i hope it did. if not heres the link
anyway, check the fuse circled in white and see if it blew. If it did, replace it with the fuse circled in blue, it's a spare.
I hope that helps!!
Old Jul 31, 2003
seijin_av's Avatar
oh, btw, the fuse box is under your hood on the left side. it has a black cover on... xP you said you were "new" to this, so just tryna make it as easy as possible
Old Aug 1, 2003
LudlamTheory's Avatar
i boogie for the raindrops
check the fuse under the steering wheel too, the accessory cig lighter fuse likes to blow up quite often
Old Aug 1, 2003
SeCosCiV's Avatar
Pimp Juice Distributor
From: Dallas, Tx but now Virginia Beach, VA 'cause of job...
SeCosCiV is an unknown quantity at this point
Koss...they still make those?
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
superstanko
Apr 28, 2015 04:38 AM
dano2005
Apr 14, 2015 01:58 AM
Unstoppable
Nov 7, 2001 11:50 PM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
