12v AC wiring
Old Jul 12, 2003
SMBFC's Avatar
SMBFC is an unknown quantity at this point
12v AC wiring
Ok, im pissed off right now. I just took some time on my sat to hard wire my radar detector to my AC outlet. I ran a wire up from the radar to where the mirror is, across (under) the roof, down the pillar, under the steering collum, and behind the 12V AC. Split that wire, and put in a switch, grounded the switch, wired (and yes no wires are crossed over), and then put everything back together. Started up the car, radar turned on with the car, went to flip the switch to make sure it works, and sure enough the radar went off. Flipped the switch, and nothing, flip, flip,flip, car on/car off, still nothing, think i may have blown a fuse BUT WHY! its a pilot 12v switch, rated for cars, and i have no idea why this happend, and if i replace the fuse, its just gonna happen again!!! what can i do?!
Old Jul 12, 2003
WhiteRabbit's Avatar
did you reverse the pos and neg wires by mistake? the white stripe isnt always ground, isnt always positive....
Old Jul 13, 2003
SMBFC's Avatar
did yellow as + and black as - and grounded the switch to the ground bolt behind the 12v AC adapter...
Old Jul 13, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Well. . . unless you've got a different car than the rest of us, it should be DC power in your car.
(Just couldn't resist that one. . . lol)
Okay. . .
1. Should always have spare fuses laying around, anyway. . . so I'd go buy some. They're pretty cheap.
2. It's possible the switch is a dud. I've actually seen this happen a time or two before. Try wiring it temporarily without the switch inline and see if it still doesn't power-up. If not, then you might have somehow toasted the RD. (This is, of course, after checking the fuse for that power line.)
3. Bad ground. Not likely, but just make sure everything really is screwed-down tightly.
Hopefully it's one of these scenarios. . . would suck *** if somehow your RD is really fried.
Old Jul 15, 2003
SMBFC's Avatar
DC/AC, yea... they both will kill me in the end. Well I replaced the fuse last night, and POP it went again, the fuse keeps blowing. I am gonna rip the wiring out today, and start over. Currently with the RD unplugged, the fuse does not blow. Hummm... well after i rewire AGAIN, i will post what I did, maybe I should do a DIY, i will grab the camera, and take some pics of hardwiring the RD.
Old Jul 15, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Before you rip it all apart try replacing just the switch.
Old Jul 15, 2003
SMBFC's Avatar
true, i do have a extra 12 v switch, but only 2 fuses left.. hummm... decisions.....
Old Jul 15, 2003
this is a classic problem of reversing the + and - battery terminals, id triplecheck, i really really would.
Old Jul 15, 2003
SMBFC's Avatar
ok i had both + and - to the switch... DUHHHHH.... omg.... i shall never show my face again...... for those who don't know what im talking about the switch is supposed to have + in and + out on it as well as the ground.... argh......
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
