question for peeps that know about hooking up amps...
Old Jul 7, 2003
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
first off... i have a 2 channel 75 watt amp.... and i hooked them up with some bass shakers.... (if you guys don't know what they are, they are thest two round things that shakes when bass hits) anyways.... i hooked up both of these two channels to two bass shakers.. and i jut got a bazooka from my friend.. actually i just took it from his garage cause he was not using it.... the question is... you think its alright to hook that bazook to the amp? or will it do something weird? like blow or just turn off or something? the way i'm going to hook it up is.... (first channel + - bass shakers) (second channel + - second bass shakers)... and
(using first channel + and second channel - hook up the bazooka)... i've already tried it and it worked out fine.... well i only had it on for maybe about 40 seconds...and nothing happend... so what you guys think?
Old Jul 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
if it worked it worked... thats called tri mode.
Old Jul 10, 2003
jkim1978's Avatar
i tried it out today and the amp turned off after like 40 minutes of playing.... does anybody know how i can hook up three things to a 2 channel amp so that my amp will work fine? the amp didn't blow or anything but it went into protection mode... and just turned off.... any experts on amp with any help can help me out.... that will be appreciated.. thanks....
Old Jul 10, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Sounds like you're overdriving your amp. 75x2 isn't much, and by it turning itself off like that it's screaming at you to give the tube back to your friend.
Old Jul 10, 2003
alex053's Avatar
where are your gains set at and what is the impedance of each thing you have on there? what size power and ground wire?
Old Jul 10, 2003
dups's Avatar
dups is an unknown quantity at this point
Some amps don't support the tri mode wiring, maybe check to see that your amp does it.
SidCivic
17
Aug 23, 2015 03:14 AM
OldschoolCool
Aug 17, 2015 05:05 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
sch2cm
Jul 21, 2015 09:58 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
