Rally Suspenion
Old Jan 16, 2018
RallyCiv's Avatar
RallyCiv is an unknown quantity at this point
Exclamation Rally Suspenion
Hi, does anyone here do any form of rally with their civic? Preferably 8thgen. I'm curious about who's the best to go to for suspenion parts.
Old Jan 17, 2018
mac25's Avatar
Dr Krieger of Modification
Re: Rally Suspenion
Do you mean autocross?
rally cross?
or Time Attack solo events like Pikes Peak?
Old Jan 17, 2018
RallyCiv's Avatar
Smile Re: Rally Suspenion
[img]https://cimg9.ibsrv.net/gimg/www.civicforums.com-vbulletin/1800x999/80-autocross_spun_stang_cool_cars_2cbddfbf5327992d4c1 8791332a65122997da889.jpg[/img
rally cross?
[img]https://cimg2.ibsrv.net/gimg/www.civicforums.com-vbulletin/640x640/80-13151119_1086250014800743_433778040_n_2557e3dc0a19 336be2ec5e85c68c9ab92c96bd9d.jpg[/img
[img]https://cimg9.ibsrv.net/gimg/www.civicforums.com-vbulletin/800x533/80-pikespeak12results_2_75782a897c72ca93a5943c1925fb3 2d1f90a15d8.jpg[/img
As in autocross.. *Stage Rally*
Old Jan 18, 2018
Re: Rally Suspenion
try thmotorsports?
I have an 2002, never used them, so no idea. They are for asphalt use, though, but could get back to stock ride height
https://thmotorsports.com/ksport/ksp...i-2452835.aspx
Old Jan 21, 2018
mac25's Avatar
Re: Rally Suspenion
I autocross.
It doesn't really mater who you buy the parts from or if you make them yourself, it only matters if they work.
If you buy cheap coil overs you'll probably end up sacrificing dampening adjustment (which sets who stiff the struts are). I did this because I don't really care.
I'm running Raceland coil overs. They run $500 for a set.
Or you could go with Skunk2, Tein, Spoon and many more but those will be $2000+.
Here's my set up
-front sway bar deleted (you can only do this with rear camber adjustment or you'll over steer into a ditch, consider your self warned).
-rear sway bar 24mm from Progress (any brand 22mm to 26mm is fine, or OEM from an si or rsx)
-swaybar end links from Jegs
-dc racing strut bar (it is important to find a solid bar not a bolted together three piece bar, but if you get a cheap three piece form ebay, set it to your car, spot weld it, then weld it tight)
-dc racing camber kit
-2 inch custom spacers
-Raceland coilovers
-Energy Suspension bushings
Also get a good set of semi track or full track tires.
Old Jan 21, 2018
mac25's Avatar
Re: Rally Suspenion
I'm not sure how the frame is built around the 8th gen civics in regards to the rear srtuts, but for the 7th gen buying a rear strut bar is pointless IMO. Double check with an SCCA racer who runs one.
My car at 6minutes and 6:20... the clip isnt the greatest but you can see that there is almost no body roll.
Old Jan 21, 2018
Re: Rally Suspenion
Cam,
The majority of coilovers will not get to stock ride height, but for rally, you want as much travel as you can, so I would not recommend that. Coilovers have the shock body designed short for lowering craze...
Also, the spring for road application are designed for asphalt, so usually too stiff for rally lower grip applications.
What matters to rally is compliance. Not a narrow window of operation.
Yoyoio
Vancouver
Jan 24, 2005 01:24 AM
Hwoody77
Oct 28, 2002 09:12 PM
Hwoody77
Oct 28, 2002 02:31 PM
CivicLX620
Ohio
Jul 18, 2002 06:49 PM
CivicLX620
Feb 1, 2002 06:47 PM
