Dash lights
Old Sep 20, 2012
wespat17's Avatar
wespat17 is an unknown quantity at this point
Dash lights
The lights on the three switches fan,temp on the dash will not light up. How do I get to the light behind the pannel to change it. Thanks
Old Sep 20, 2012
Re: Dash lights
Year/make/model of your car? DX EX LX etc., 2/3/4 door? (Put this info in your profile too.)
You posted this in 2006 and newer.
Old Sep 20, 2012
wespat17's Avatar
Re: Dash lights
2002 EX Civic 2 door
Old Sep 20, 2012
Re: Dash lights
Pull out the trim (center panel) that holds the heater controls, then you should be able to figure out how to get to the individual bulbs once the panel is out and in your lap.
Tiny screwdriver, 1/4 turn to release, for most of these bulbs.
To remove the center panel:
Remove the dashboard center lower cover.
<table class="S2"> <tbody> <tr><td>Remove the bolts (2) from the dashboard center lower cover opening. (These point upward.)
</td></tr> </tbody><tbody></tbody></table> <table class="S2"> <tbody> <tr> <td nowrap="" valign="top">
</td> <td>Gently pull out along the bottom to release the lower clips, then along both sides and top to release the remaining clips.</td></tr> </tbody><tbody></tbody></table> <table class="S2"> <tbody> <tr> <td nowrap="" valign="top">
</td> <td>Disconnect the hazard warning switch connector, radio connector and antenna, fan switch connector, and heater control unit connectors.
HTH
</td></tr></tbody></table>
Old Sep 21, 2012
CraigW's Avatar
Re: Dash lights
I would just do all 5 bulbs at once... I did it on my 05 and they were much brighter (the bulbs get a black buildup inside them over time)
Just look for the audio unit removal procedures to follow, super tight if it has ever been out. You may need to reach in behind at the acc socket area and push out.
Old Sep 21, 2012
rjones7755's Avatar
Re: Dash lights
I swear this is gonna sound stupid but my car does the exact same thing sometimes, here comes the stupid part- if you use the bottom of your fist and hit it once on the left side of the dash it'll come back on, (at least for me) My old 01' and my 04' both did it. Lemme know how it goes lol
Old Sep 21, 2012
wespat17's Avatar
Re: Dash lights
Good job it worked for me! Thanks
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
antidote11
Dec 8, 2001 09:32 PM
