Sponsored by:
Sponsored by: CARiD
Hid kit in projectors
Old May 18, 2003
curt's Avatar
curt is an unknown quantity at this point
I know that you probably have to change the projector out with a hid compatible projector.
i have the halo's i was wondering if i went with lets say catz 42-4500 i cant remeber which one it is but you know what im talking about, would i have to change the projector or no, i hate having the stock color bulbs in there and every time i put in higher watt bulbs they kept blowing, so i was wondering and any infor would be great.
thanx
Curt
Old May 20, 2003
showoff's Avatar
showoff is an unknown quantity at this point
You can get a HID kit and then plug em into your TYC projectors, but if you have a little more patience and some fabricating ingenuity you can also buy OEM HID projectors then retrofit them into the projectors for the same price. I just bought a set of E-Spec ECE Audi A6 projectors and im currently in the process of retrofitting them into the TYC housings. After plugging in these projectors there's not a doubt im my mind that i made the right decision and I paid alot less than the usual Plug and play kits would cost.
Old May 23, 2003
curt's Avatar
How much did they cost and where did you get them, also how much will it cost to put them in.
I dont have the TYC's I have the halo projectors.
They should still work right.
Old May 27, 2003
showoff's Avatar
I got my Audi A6 ECE Hella projectors w/ 4100k 8122 D2s Philips bulb and Audi OEM ballast w/ wiring harness for $375.00. Both TYC and Halo uses stock H1 bulbs so the projector unit dimensions should be similar. I just finished aiming and mounting my HID projectors in my TYC's yesterday and all i can say is WOW. The beam pattern is so much cleaner and noticably brighter than any DOT spec unit on the street. Even a stock DOT A6 seems to be dimmer and less wide than the ECE version of the same unit. I'll post pics when I get my girfriends digicam later this week.
Old May 27, 2003
Voiceofid's Avatar
End Bringer
Finished A6 HID retrofit, with lots of pics.
Old May 27, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
cool post pics. I want to do this to my angel eye projectors cuz i can't see ish even with the high beams on
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
