Sponsored by:
Sponsored by: CARiD
D17A2
Old Apr 9, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
D17A2
I believe Honda just stroked a D16 motor to get the D17A2. Does anyone know the complete engine code of which D16 motor was stroked? Or ideas on where i could look this up?
I want this to try to figure out what parts can be swapped into our motors.
Thanks!
Old Apr 9, 2003
R3DL1N3's Avatar
i dont get why people are destroking their engines to D16s. D17s have more torque..so why? please fill me in
Old Apr 9, 2003
RiceBuRNeR's Avatar
Turbo Member
You might want to take a look at this thread that I posted a while back.
Old Apr 9, 2003
cambo's Avatar
I wish I was asian
the d17 is not a stroked d16,
completely (well...not completely) redisgned. bolt patterns are different and such.
Old Apr 9, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Hey RiceBuRNeR
According to Edmunds.com the 92 Acura Integra GSR has a 1.7 liter engine. You think the pistons might fit? How much will have to be done for our engine to use them?
Or is it a misprint?
Old Apr 9, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
B series have a larger bore than ours.... it's 81 vs 75 mm. To make the stuff fit, you'd have to over bore the cylinders 6 mm... which is quite a bit. I don't know what the stroke is, but it's shorter than ours... so in theory using B series pistons would bump the displacement in our engines up considerably. I'm sure it's possible, but I don't know exactly what's involved... it's probably expensive.
Old Apr 9, 2003
Ike's Avatar
Ike
oh, ok
appreciate it
Old Apr 9, 2003
Jap-Euro Fusion
Originally posted by Ike
oh, ok
appreciate it
Since you set the other thread to be deleted.. here's the explaination that I posted over there in case anyone wonders....
"B series engines are more neutrally balanced than D series engines. I mean, they have a larger bore and a shorter stroke to get the same displacement. It provides a more even power curve and more overall power. D series engines are actually torque biased (stroke is longer than the bore is wide) and they still make more HP than torque, the B series is torque biased too, but not nearly as much. D17's are 75x94mm (bore x stroke), B series are 81 x something in the mid 80's. I think the B16 is 81 x 84."
Old Apr 9, 2003
Ike's Avatar
Ike
oh, ok
So the stroke is longer than the bore, which makes it unbalanced.
Old Apr 10, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
also our cars pistons are slightly oval shape, and i think those GSR's are completely round....
Old Apr 10, 2003
Da2K1's Avatar
Thanks guys! I was asking, as i wanted to see if it was possible to get a stroker kit for a D16 (there are some available to make it a 1.8L) & replace the pistons for higher compression; to give me a D- series motor that rocks . Our pistons are actually round, here's a link to some interesting info..
http://www.heeltoeauto.com/dseries/dseries1.html
Thanks RiceBuRNeR! You've now given me another option
BootyDo
Jun 21, 2016 03:45 PM
mac25
Aug 21, 2015 11:14 PM
tock172
Jul 21, 2015 06:25 PM
alex_nyc
Jun 16, 2015 08:12 PM
jmdcivic
May 20, 2015 09:52 PM
