Sponsored by:
Sponsored by: CARiD
K&N Filter... what will it do?
Old Apr 9, 2003
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
I'm a kinda new to the civic, and i got 1 not to long ago. Right now i'm puttin payments on a body kit, so my budget is low. Will a K&N air filter make any noticeable performance in my car? What about that tornado air flow thing?
Old Apr 9, 2003
Dr5D's Avatar
they say that replacing the stock filter with a k&N dosent do much for power on our cars, but nothing does, anyways, they just told me that it makes it so you dont have to get a new one hardly ever, if ever.
am i making any sense? eh
Old Apr 9, 2003
PunkingCivic's Avatar
I need TP for my bunghole
yes,
the K&N will increase air flow and the filter is also washable and reuseable.
The tornate will also be good for the car.
Increased gas mileage.
Better air to fuel mixer.
More air compressed into the cylinder for more power.
Ever little bit helps
Old Apr 9, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Don't listen to that part
Old Apr 9, 2003
slystad810's Avatar
If you don't mind burning your money on useless rice then go ahead and buy the tornado.
It may have a small effect on carburated engines, but not on our cars.
The main benefit of a K&N drop in filter is that it is reusable. It does provide better air flow, but you will not notice much if any gain in HP.
Old Apr 9, 2003
Bartkat's Avatar
Tornado not do anything for 7th gen civic.
K&N filter lasts long time. Wait till you need a filter and then get it. Can clean and keep for years and years.
Old Apr 9, 2003
Grey's Avatar
DIY King
I have the K&N drop-in air filter. I think I noticed that the car was a bit smoother at higher rpm's. Mostly unnoticeable though. Eh, it's kinda k3wl 'cause you can re-use it for the life of the car.
Old Apr 9, 2003
Dr5D's Avatar
eh, maybe a stupid question - is it possible to use the tornado with a cai?
youd just have to get the right diameter right?
Old Apr 9, 2003
Bartkat's Avatar
Why?
Old Apr 9, 2003
Mbow's Avatar
Uh, most likely it will do nothing. It may give you .5hp or something...
The main benefit of the oem replacement is its ability to be reused. If you plan on keeping the car for several years, it will more than pay for itself.
Old Apr 10, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
it will save u a buck or two~ cuz washable/reuseable
http://www.ajusa.com/cgi-bin/knfilte...rt_num=33-2192
i got from this site, might be good site to compare tho $.....
Old Apr 10, 2003
Bartkat's Avatar
That's a good deal, depending on shipping charges. It's $37.99 here, where I got mine.
http://www.performancecenter.com/pro...CIVIC&sf4=1.7L
I can say for sure these filters will last, if you take care of them. I've had the K&N OE replacement filter in my Firebird for over 90,000 miles.
Old Apr 10, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I just bought the drop in filter and installed it last week. I don't feel any power gains, but it feels like my car breathes more easily. As for gas mileage, its wierd. I usually get at least 30mpg until the gas light comes on. I fill 10 gallons everytime = 300miles/tank. Well after I got the filter I only averaged about 27 mpg before I had to refill today. Maybe its because I was driving my car a bit harder during this fill up than I usually do. I will do a full fillup tomorrow and see the results again. I should be getting MORE gas mileage!!!
Old Apr 10, 2003
CapYoda's Avatar
Escaped Convict
yeah u should be getting more gas mileage.
I got 3-4 more mileage.
no noticable performance increase, but i dont care.
Old Apr 10, 2003
Grey's Avatar
DIY King
Oh yeah, I think I noticed an increase in gas mileage. It's tough to tell though...
Old Apr 21, 2003
hondamexicano's Avatar
hondamexicano is an unknown quantity at this point
I just intalled the drop in filter, looking for better gas mileage. Good to know you are getting 3-4 more mpgs.
Can the tornado be installed in our cars? The guy that sold me the k&n wanted to sell me that thing, but after looking at the air intake told me it wouldnīt work. Thatīs supposed to really improve your gas mileage.
As for more HP, in theory you can gain up to 5 HP, but itīs only noticeable at high speeds and high rpm. The advantages of the k&n are really its long life and a better breathing engine.
Old Apr 21, 2003
Bartkat's Avatar
Tornado doesn't do anything for 7th gen civic.
Old Apr 21, 2003
slystad810's Avatar
3-4 more MPG? That sounds a little high to me. Maybe 1-2 at the most.
Old Apr 21, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The stock air filter is garbage after about 12,000 miles. That is because it is right above the throttle body and tends to pull air from right above it. When that area gets saturated with dirt, you will notice a loss in power. Since now it has to pull air from around the filter.
The K & N will only allow you to not have to buy a filter and it will last a bit longer between cleanings. I did not notice any real gains from it.
Now getting an intake is a little better. I noticed a big change when I got the FIPK. It really depends on what you want to do. If you want to keep your car stock, then just get the filter drop in. If you want some increase, get an intake.
Just think carefully if you want to get a cold air intake. A few people have learned the hard way about sucking in water when they go through a puddle.
Old Apr 21, 2003
CapYoda's Avatar
Escaped Convict
I calculated over three full tanks of gas and I did got 3-4 more mpg.
I was doing the same type of driving as I would have done...
3-4 is a lot, but er.. I got 36-37 when I usually would get 32-33 mpg.
Old Apr 21, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
with my sri intake, i lost about 4mpg
Old Apr 23, 2003
Interesting. I actually got a full tank the same day I installed the k&n drop in. I will post my mpg readings once I refill the tank. I donīt think I will get 3-4 mpg more because I have 225/55 16 tires.
The water sucking problem was the main reason I decided to keep stock. There are a lot of floods where I live.
em2 10
Bolt-on Engine Performance
May 26, 2014 05:52 PM
zerochance
Sep 28, 2013 09:17 PM
Szady
May 13, 2013 01:16 PM
90civicbns
Jan 10, 2013 04:49 PM
CapYoda
Sep 6, 2002 11:47 AM
