Dirty engine......
Old May 26, 2014
em2 10's Avatar
em2 10 is an unknown quantity at this point
Dirty engine......
I need to clean my engine and intake filter... Is it safe to use engine cleaner under the hood and rinse it with water??? Will it mess up any sensors? And should i leave it running or in the off possition?
Old May 26, 2014
Re: Dirty engine......
Everything in the engine compartment is water resistant. Everything can get wet when it rains or snows.
Not water PROOF, so you still have to be careful. Don't use a pressure washer unless you really know what you are doing as far as correcting electrical problems caused by water entry,
JMO
Old May 26, 2014
em2 10's Avatar
Perfect thanx for the advice
Old May 26, 2014
em2 10's Avatar
Should i leave the car on or off when cleaning it????
Old May 26, 2014
GolNat's Avatar
Prelude Owner
It will tell you on the back of the engine cleaner can. I believe it is suppos to not be running but should be warm. Read the can!
Old May 26, 2014
em2 10's Avatar
Thanx for the advise
Sep 27, 2015 11:33 AM
Bricoleur
Sep 9, 2015 12:30 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
RIPSAW
Aug 16, 2015 12:14 PM
Deejai35
31
Jul 19, 2002 04:01 PM
