Sponsored by:
Sponsored by: CARiD
high flow cat?
Old Jan 3, 2003
civicRS's Avatar
civicRS is an unknown quantity at this point
high flow cat?
is it true that high flow cat gains a lot? and would it produce noise with it.... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 3, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Yes they do make the exhaust a little bit louder. All the gains that I have heard have only been minimal. They are really good if you are running racing fuel.
Old Jan 3, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
You won't feel anything. there would be more of a difference if you had FI and went from stock to highflow. They will quite down your exhaust alot if you don't have a cat but louder if you have a stock cat. not much of a difference from stock to high flow, At least I didnt' notice barely any.
Old Jan 3, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
even with an aftermarket cat back, the catalytic conveter is still the least restrictive part of the exhaust system.
Old Jan 3, 2003
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
With just a high flow cat, the gains will be minimal because you still have the restriction at the factory exhaust manifold. There's only a minimal amount of power to be gained from the D17 engine, but replace both the header and cat, then you'll feel a difference.
As for the sound.....a high flow cat may make things a bit louder at certain RPMs. The resonator is what quiets things down. Take that off and it will be much louder.
carid
Nov 7, 2015 01:46 AM
jzhartman
22
Jul 23, 2015 10:42 PM
cizsak
Jul 21, 2015 03:39 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
silentz
Jul 9, 2015 08:16 PM
