Sponsored by:
Sponsored by: CARiD
Replacement Pedals
Old Apr 18, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Replacement Pedals
I want to get replacement pedals, not just pedal covers! Anybody recomend any that will fit our cars? Or are most pedals a universal size like shift *****? I want the whole silver w/ red insert look, help me out guys! Thanks!
Old Apr 18, 2002
FURY's Avatar
FURY is an unknown quantity at this point
yeah those racing pedals are universal
Old Apr 18, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
if i remember right, the pedals are welded onto the levers to control the gas/brake/clutch, so you can't really replace the pedals completely without a lot of work. if you do it though, post pics, that would be tight!
Old Apr 18, 2002
SWEETRIDE's Avatar
SWEETRIDE is an unknown quantity at this point
I think it's a lot of work to totally replace them, If you got the time and $$ though Post some pics if you do the deed![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 18, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
I have some genuine Honda pedals from Japan that you actually have to drill holes into the metal base pedals (after you remove the rubber boot) and screw on. The brake & clutch will be easy but the gas pedal in our car is not just a metal pedal with a rubber boot on it. Going to take a little more effort to make it work.
Old Apr 18, 2002
FLY's Avatar
FLY
FLY is an unknown quantity at this point
pdal covers are nice though i think you should reconsider you cant even tell they are pedals unless you put your head down on the floor board
Old Apr 18, 2002
nbpEMCivic's Avatar
I had pedal covers and they just sucked ***. Looks like I have something to do then, if its gonna take alot of work to replace the pedals....time to do some research!
Old Apr 18, 2002
nbpEMCivic's Avatar
Well I went out and took a looksie...the clutch and brake pedals are covered by some rubber **** covers, the pedals themselves are black metal welded to rods and junk. I can get some nice pedal covers "momo or sparco" and drill them into those pedals easlily, but the gas is different. Its plastic and is connected in a strange way. I think it is screwed in, but I couldn't look on the side of the pedal close to the passenger as there is no freaking room over there. Maybe I could drill there too. Shouldn't be too hard, and with them drilled in they would stay put. Oh and the dead pedal can be taken out, its a bolt on.
Old Apr 23, 2002
GSTARR's Avatar
GSTARR is an unknown quantity at this point
got some RAZO CF pedals. check them out in members rides
Old Apr 23, 2002
GreenVenom's Avatar
GreenVenom is an unknown quantity at this point
I replaced mine with indeglo petals and all i had to do was take off the black rubber piece and clamp on the new ones worked great. most should be universal though!!!!
GreenVenom
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
thesushiboy
Apr 12, 2015 02:54 AM
Aznnp77
Bolt-on Engine Performance
17
Jan 9, 2004 01:12 AM
darelldd
General 7th Gen
18
Feb 24, 2002 06:31 PM
