215/45 or 205/45??
215/45 or 205/45??
according to the tire calc, this is what I found for the speedometer reading with 17" rims
215/45 = 0.61% too slow
205/40 = 0.84% too fast
so what I would like to know is what would be better...I think the lower percentage, but am not 100% sure...
Thanx
Thanx
I have 215/45's, they fit perfectly....they match up perfectly with the body panel...not to mention a bigger patch...
With 1.5" drop they my rub the plastic fenderwell-trim in the front on hard-cornering...but no biggie...
According to This Tire Calc. going with 205/45/17 leaves you with lower milage on the odometer.
So going 1000 miles on stock tires gives you 1000, but with the 205/45/17 you are left with 997.24 and some change. I personally would go with that just to b under.
there's the answer i was kinda looking for...so you say i'll actually be speeding a little more (than I do now:laugh[IMG]i/expressions/face-icon-small-wink.gif[/IMG] but my odometer will register a shorter distance than I'm actually traveling?
My bad, now that i've researched the topic with 17 inch rims on our cars, you need to go with 215-45s. Its the closest matching tire size. 215 40's will not only throw off your instrumentation, they will also throw off your suspension geometry, when you change overall wheel diameter, you change the radius of the tire to the ground. When this occurs you are cahnging the cars camber and allignment. Be sure to address both issues if you do go to a tire size different than 215-45 R17's
RF Bwoy
RF Bwoy
