Plus sizing and Rubbing tires
Old Jun 26, 2002
ZRPM's Avatar
ZRPM is an unknown quantity at this point
Hiya all, I'm seeing a few posts about tires rubbing with 205/45 17, and wider tires.
Does anyone have their car lowered 1.5" and have 215/45 R17 tires? Do they rub?
I was set on getting this size, but I'll be dropping my car probably with the Eibach Sportline springs. If the tires rub, I'll need to figure out something else....
What do you guys run, springs and tires that do not rub. Messed up camber is not an option for me...
Old Jun 26, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Humm yeah I am looking to get 225/45/17 for rims with no drop so I am still wondering if I will rub.
Nick
Old Jun 26, 2002
ZRPM's Avatar
225... maybe, you may rub I think. I know you won't rub without drop on the 215/45 r17, but I'm not sure if the car gets dropped. I'm looking at the sportline 1.4" drop. I may get some Koni Shocks at the same time to stiffen up the ride a bit.
Old Jun 27, 2002
2cute's Avatar
2cute is an unknown quantity at this point
The tire size really isn't that important in that equasion. Most likely they rub because there is an improper offset or no offest at all. I have a 40 mm offest dropped 1.3 inches and 205/40ZR17. I do not have any rubbing problem.
Old Jun 27, 2002
ZRPM's Avatar
Yeah, 40 offset is a given. The 215/45 are a touch wider and taller. You may be right, it may be a non-issue.
Old Jun 27, 2002
2cute's Avatar
Let me put it this way I know you can easily put 19s on these cars with room to spare. My boy has 18s with 215/35R18 and his 7th gen vic is dropped 3.5 inches he has no rubbing problems.
Old Jun 27, 2002
ZRPM's Avatar
What's the camber like with the 3.5" drop?
I'm only going 1.5" so camber may not even be a problem. Can't wait to get my rims
Old Jun 27, 2002
2cute's Avatar
LOL it is really nasty on the back. The front is fine since the front wheels will not go far enough out of camber to matter due to the McPhearson struts. But the rear is BAD.
Old Jun 27, 2002
ZRPM's Avatar
If you fix the camber in the rear, it still may NOT rub, because these are the non-turning wheels. Just a thought. Might be worth some exploration
Old Jul 2, 2002
Edens's Avatar
Edens is an unknown quantity at this point
I had 235/40zr17 on 17X7.5 wheels with a 42mm offset and my car was lowered 2 inches all around and had 1 degree negative camber in the rear and .5 neagative camber in the front and they didn't rub anywhere
OptimisticWay
46
Oct 15, 2015 02:16 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
