Egay fogs with an ion lense
on the + side, the burnt film didnt damage the lens. so you can just peel it off. i tried it again with stock bulbs instead of nokya and same problem lol. finally went to projectors and they are much better at lighting the ground and i can touch the lens without burning myself.
mostly old pics but yea. theyre bmw style from ebay, takes H3, im using luminics yellow and i also painted the bowls with krylon stain glass paint. they are alot dimmer than before, but i like the yellow look with hid.
They became dimmer with the projectors... I find that hard to believe-- or because of the stainglass paint? I thought about doing projectors, but doesnt the beam suffer in rainy dark weather?
Re: Egay fogs with an ion lense
Hey Triz,
I'm thinking of purchasing the exact Fog light kit that you have...and from the same supplier. Can you elaborate on the installation eg. Did the harness install as expected? The quality of the switch.
I saw this link for installation procedures and was wondering if this worked for the kit you purchased. (Eighth item down the page)
http://www.handaccessories.com/civext01.html#fog
I can take some shots tonite if you really want with some actual ourput, but this is what they look like from head on. I agree with gearbox that the yellow looks real good with HID
Hey Triz,
It went pretty much like that. Look at the connector thats under the passanger headlight. That saves having to run a wire through the firewall. I basically followed it, but didnt do the wiring of the switch the same. I got an on-off amber led lighted switch, three prongs, in, out and ground. I like it, only down side is that it doesnt beep if I take my key out with it on, it'll just keep running. But the led light is pretty bright and hard to miss when getting out. I only left it on during the day once when I first installed them kuz I wanted to show off a little or something.
Anyways, PM me if you have quetisons
i bought the amber one from ebay and they sent me the ion..but its ok.it does give some amber look..but i think i will replace it wit the hyper yellow to see how it look..
alinaray
18
Aug 24, 2015 01:04 PM
j-chest
Jul 31, 2015 01:18 PM
