Sponsored by:
Sponsored by: CARiD
Questions about the TYC projector headlights please?
Old Mar 15, 2002
jimmymingdahai's Avatar
jimmymingdahai is an unknown quantity at this point
I was just wonderring what kind of light bulbs are used on the low beam and high beam on those TYC projector headlights? I already bought them but I don't know what kind of bulbs I should buy along with them..already had some H3 bulbs for the high beam..do I need another pair of H3 bulbs? Thank you.
Old Mar 15, 2002
slikor's Avatar
slikor is an unknown quantity at this point
i havent got my TYC's yet, but VoiceOfId, who has a pair on his car, told me based on what the bulb looks like he thinks both the high and low beams are H1. i may be wrong, or i might have remembered what he said wrong, but the best way for you to find out for sure is find a pic of H1 and H3 bulbs and compare what your bulbs look like to those. worst case, just take your high and low beam bulbs to like a car dealership or a shop or something and they will [hopefully] know.
Old Mar 15, 2002
thanks a lot![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 15, 2002
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
The bulbs in the projectors are H3 the high beam Im no to sure of....[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 15, 2002
OK guys, I'm kinda confused..are they H1 or H3?
Old Mar 15, 2002
tcneo's Avatar
tcneo is an unknown quantity at this point
both low and high are H1 (for sure, coz i just checked it - the headlights are sitting behind me) [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 15, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
i heard also that the beams were H1 and H3, but im not 100% on this one, let alone do i know which one goes to which! ahaha, sorry!
Old Mar 15, 2002
I can't believe it..the guy at the import revolution who sold me the bulbs told me that they would fit those TYC projectors..and they had a pair of them there too!! So now I gotta order another two pair of H1 bulbs? Does anyone know where can I get them cheap online? Thank a lot again..
Old Mar 16, 2002
eXNBP's Avatar
eXNBP is an unknown quantity at this point
try www.groupbuycenter.com need membership to view it (dont worry itll take like 2 seconds).
Old Mar 16, 2002
Voiceofid's Avatar
End Bringer
far as i know, high/low uses h1 bulbs, because h3 has that wire thing comming out, and mine doesn't plus, glad we don't use h3, because they do not make hid for h3s
Old Mar 17, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
actually there are like 3 companies that have HID for the H3 bulb...i know because ive seen with my own two eyes.
Old Mar 17, 2002
tcneo's Avatar
<< far as i know, high/low uses h1 bulbs, because h3 has that wire thing comming out, and mine doesn't plus, glad we don't use h3, because they do not make hid for h3s >>
one more thing... the light pattern on H1(horizontal selenoid) is more similar to HIDs(spread the light vertically), coz the selenoid in H3 are vertical.... thus it spread the light horizontaly.....
it'll be clearer if u compare those 2 bulbs and see the parts that light up
Old Mar 17, 2002
showoff's Avatar
showoff is an unknown quantity at this point
<< one more thing... the light pattern on H1(horizontal selenoid) is more similar to HIDs(spread the light vertically), coz the selenoid in H3 are vertical.... thus it spread the light horizontaly.....
What are you talking about? Beam pattern is determined by optical placement of the filament within the light housing. No matter what direction the filament is vertical or horizontal it will not affect the beam pattern. Only when the actual hot spot of the filament is moved outside reflective or parabolic range it changes the beam pattern. Also HIDs don't have a vertical spread its arc is only controled by the housing its encased in. The HID bulb doesn't have any vertical or horizontal positioning like a halogen bulb it is centrally located in the middle of the quartz glass tube.
Old Mar 17, 2002
tcneo's Avatar
excuse me there.... heheh i don't mean the beam pattern as what comes out from the projector.... but look at it as the beam that comes out from light source itself... H1 and HID spread vertically (imagine seeing the lighted HID bulbs minus the reflector from one of it's end.... it's not as bright as if u see it from above/below) and H3 horizontally.
that's why a retrofitted H3 HID won't work as good as the other bulbs unless you position the HID bulb vertically, the beam coming out of the light sources doesn't behave in the same way if u placed both in the same manner (both vertical or horizontal)
this behaviour is described in this page, look at the description for H3 HID and H1 HID
Old Mar 20, 2002
VTECpnay01's Avatar
VTECpnay01 is an unknown quantity at this point
H1!!!![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
civic98?
Aug 13, 2015 01:32 AM
knknif
Aug 4, 2015 06:11 PM
DerbyDad03
Jul 27, 2015 11:34 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
NoobyKid
Jul 13, 2015 07:53 AM
