Sponsored by:
Sponsored by: CARiD
ATTN: People with projectors
Old Feb 3, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
PLEASE READ BEFORE YOU CLICK THAT REPLY BUTTON!!!! this is my second attempt at this topic, and last time almost everyone posted things that were completely irrevelant to the topic
I want to get black projectors, but i have heard that some people are having problems with the hiper industries ones and had to modify them so they would work right. anyone with the APC brand projectors have any problems with them, or is it a case of you get what you pay for with the hiper industries projectors? How well do the lights work with the bulbs that they come with/call for (not hyperwhites, etc), is there any problem with the projectors fitting or bulbs fitting in them? make sure you list what brand youre using if you do have any problems
DO NOT post a link to someone in members rides with a pic of black projectors. i know what they look like and that is not what im asking
click here to see the previous post where people didnt read before posting
things to post:
1) brand of projectors
2) how well the light up the road
3) any installation problems
Old Feb 3, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
Im not sure about the question but i want some black projectors to so i would like to know the replys to. And also like where is the cheapest place to buy them.
Old Feb 3, 2002
pmau's Avatar
pmau is an unknown quantity at this point
I use to own a pair of projectors, but not the same ones at the picture in the previous post. The ones in the previous post are supposedly made by tyc, but I'm not sure. The one's I owned looked like this projectors
Now to answer your questions. The pair I had fit like OEM. Yes OEM. It's not like other projectors where you have to modify to get it fit perfectly. If you get the projectors I got, you have align the beam because it's misaligned to begin with. It isn't too hard to do. If you don't correct the beam pattern, one will aim down and the other will aim up. As for the brightness, if you have the beam pattern aligned right, it does light up the road better than your stock housing. If you decided to put any type of xenon bulbs in, it will burn out faster because the projector lights draw more power. You can actually feel the projector headlamps warm up. Hope this helps.
Old Feb 3, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Do you mean that the bulbs will burn out faster or that something will happen to the projector housings faster because of the bulbs?
Old Feb 3, 2002
pmau's Avatar
Yes the bulbs will burn out faster. Xenon type bulbs tend to draw more wattage and adding the projector drawing more wattage = a faster burn out.
Old Feb 3, 2002
RSXtypeIvtec's Avatar
Su Mo
for you all interested in those projectors, i have some for sale in marketplace...check it out!!!
Old Feb 3, 2002
Diznavis's Avatar
pmau, do you know what compay made the projectors you have on your car?
Old Feb 3, 2002
pmau's Avatar
I don't have any idea's who makes it. But if I had to take a shot at who makes it, I would say Matrix, but don't hold me to it.
Old Feb 3, 2002
Diznavis's Avatar
props to pmau for answering the questions asked
there must be more people out there with experiences with projectors
Old Feb 3, 2002
vietnam's Avatar
vietnam is an unknown quantity at this point
my suck, i brought them at r speed the small parking light doesn't fit, because the housing is bigger, and my projector i can't see a danm thing on the road when i turn my on agaisnt the wall there is a line on the beam like------/\---- -----/\-------- i look at my parents car and i t didn't have any line on the wall they just faded or something, and my beam ajust broke so i had to get a fog ligt to light my way
Old Feb 3, 2002
Diznavis's Avatar
vietnam, do you know what brand they are? your problems sound like the ones i read about the hiper industries projectors
Old Feb 5, 2002
bottlefed's Avatar
bottlefed is an unknown quantity at this point
i have the matrix ones and they light up the road too good. people flash me cause they think i have my high beams on. the only probs that i have with them are that the parking light and the blinker bulbs didn't fit. the whols were a little too big. but i have the easiest way to fix that prob. i put some finger caulk around the part that goesinto the whole. finger caulk is just a round roll of stuff that looks like clay but it is like a string wraped around into a roll. just peel like 5 inches off of it and wrap it around the area that the bulb is suposed to go into the slots and just push on it and it will stick. i did this like a month ago and it's great. one more prob. i put super white bulbs in and they blew out next day and the other blew a week later so i put the original one back in and they work fine but i want the super whites. Does anyone know what i could do?
Old Feb 5, 2002
Diznavis's Avatar
good info bottlefed. maybe the reason people are flashing you is because the light is angled a little bit too high[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 5, 2002
bottlefed's Avatar
u can't change the angle though
Old Feb 5, 2002
Diznavis's Avatar
<< one more prob. i put super white bulbs in and they blew out next day and the other blew a week later so i put the original one back in and they work fine but i want the super whites. Does anyone know what i could do? >>
did you touch the bulbs? oil on your hands makes the bulbs explode if you touch them
Old Feb 5, 2002
pmau's Avatar
You can change the 'angle' of the beam. It's located behind the projectors. There should be 3 or 4 screws. You just have to turn them either to the right or left depending on how your lights are aimed. There are 2 screws for the low beam and either 1 or 2 for the high beam. For the low beam, one is to adjust the beam left and right and the other screw is for up and down. The best way to aim your lights evenly, is to put on your stock lights, then at night aim your lights against the wall and mark it. Then put on your projectors and try to match up the same 'angle'. As for your bulb problem, there isn't a way to fix the problem even if you haven't touched the bulbs. Don't try to put higher wattage bulbs in either because it can/will melt the housing. If you want superwhites on your projectors, just be willing to pay for the replacement. But I hear the Piaa bulbs draw less wattage and put out a great output. So you may want to try those if you have money to burn.
Old Feb 5, 2002
Shaitan's Avatar
Shaitan is an unknown quantity at this point
Hey diz, those projectors that you asked pmau about earlier. They look like the ones on NOPI.com that I saw. Those were made by CK Motorsports, also known as FOCUZ. I don't know if that is them, but it looks like 'em.
Old Feb 5, 2002
bottlefed's Avatar
didn't know i could change the angle but i would have to take off the bumper again to change the angle but u would have to put them on, take them off, put them on take them off, blah blah, blah to line them up. does anyone have the matrix projectors and have hyper whites and doesn't have any problems?
Old Feb 11, 2002
slikchik's Avatar
slikchik is an unknown quantity at this point
I'm still learning about cars, but it seems like projectors are a little bit of trouble. i really want some but if they are trouble I might just get clears. Do u guys know where I could look for some clears. Thanx
Old Feb 12, 2002
NightHawk's Avatar
NightHawk is an unknown quantity at this point
i have black projects, from japa...TYC. No problems, but im still figuring out how to raise the projector, cuz the left one is too low, doesnt look as purple. But, i had no electrical problems! recommend them!
Old Feb 12, 2002
Diznavis's Avatar
<< I'm still learning about cars, but it seems like projectors are a little bit of trouble. i really want some but if they are trouble I might just get clears. Do u guys know where I could look for some clears. Thanx >>
cleared headlights? thats a DIY project, you cant buy them (well maybe you might find some already done on ebay, but they are gonna cost you a lot)
Click here for the DIY
Old Feb 12, 2002
bottlefed's Avatar
Purple??? what do those have HID built in to them?? unless you are talking about just bulbs.
Old Feb 13, 2002
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
bottlefed...in yer signature its says MSD...what do u have of MSD, our ignition is individual coil packs.....let me know what you got..??
Old Feb 13, 2002
Grey's Avatar
DIY King
Check out my thread: ATTN: bottlefed
I was curious too! [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 13, 2002
bottlefed's Avatar
take a look at the thread grey suplied for you cause i don't feel like explaining again
Old Feb 19, 2002
Diznavis's Avatar
well this thread got a little more info than the last one, but still there are a lot of people with projectors that didnt respond!!
looking for brand and your experiences with them
Old Feb 19, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Bottlefed has the MSD DIS system. It is made for cars that don't have distributors, like ours. I think retail is right around $375...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
ThatGuy913
Sep 28, 2015 05:35 PM
