Sponsored by:
Sponsored by: CARiD
How many miles is a water pump good for?
Old Jun 26, 2005
Notorious SI-G's Avatar
Notorious SI-G is an unknown quantity at this point
I got this car used with 100k miles on it. It was a lease car and I'm second owner. I don't know if the timing belt or water pump has ever been changed in this car. It's a 1.7 VTEC. The dealer where it was leased has no service records for it either. Will the original water pump or timing belt go 100k miles?
Old Jun 26, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
timing belt is supposed to be changed at 90K miles. not 100. if the timing belt breaks on you while you drive go get a new engine. have the timing belt changed asap. well find out first if it has been changed. good luck
Old Jun 26, 2005
yup change the belt asap and the water pump too.
Old Jun 27, 2005
modoman's Avatar
any used car with 50k+ miles on it used i would change the timing belt just to be safe.
Old Jun 27, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Hope you didn't pay too much for it with a 100k on it. But, yes, change the timing belt and waterpump together. CHEAP insurance. If either break, new engine.
Old Jun 27, 2005
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I'm not sure that a broken water pump means new engine. As to the timing belt yeah thats a new engine most likely.
Just to let people know my experience, not saying it will be the same for everybody, I had my timing belt changed at 110K miles and when the mechanic showed me the timing belt it looked exactly the same as the new one. I was preatty surprice on how well the belt had hold for that long.
Old Aug 4, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
just inspect it for wear and check the tension on it, and you should be fine.
Old Aug 4, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
your good for about 150,000kilometers, not miles.
Old Aug 5, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
From talking to mechanics over the years, waterpumps used by Honda last on average 150K miles. The reason why people advocate changing the waterpump when doing the timing belt is because chances are the waterpump will not last until the next timing belt change. Because you have to remove the timing belt to get to the waterpump, it just make sense to replace both at the same time. Even though there may be 50K miles life left on the waterpump, if it goes, you'll have to spend the same amount as a timing belt change. In the end, it's up to you. Do you feel lucky?
Old Aug 5, 2005
civicdude's Avatar
moving to other products and parts
mattdoc
Mar 14, 2017 12:10 PM
mrohitredd
18
May 14, 2015 07:35 PM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
