Sponsored by:
Sponsored by: CARiD
check engine light came on...why?
Old Dec 10, 2004
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
today i got my megan racing down pipe in. i connected my o2 sensors and everything. for a while the check engine light didnt show up untill now. could the check engine light show up for other reason besides not connecting the o2 sensors?
Old Dec 10, 2004
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...d.php?t=185499
Read through that it explains about a mil elimintator thingy that you install to trick your ECU
Old Dec 10, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
what mileage are you at...it might just be coming on becuase you need an oil change
Old Dec 10, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
^the check engine light, oil indicator and/or the maintaence required indicators will turn on if its motor related issues.
you need an mil elminator in order to lose that malfunction indicator lamp (yellow figure). its on because your secondary o2 sensor isnt reading the right amount of air pushing thruout your exhaust's system. theirs no way you can get rid of that light "naturally" with a hi flow cat or going catless.
as for the damage, its not causing any and its just their to tick you off. but i would suggest investing into a mil eliminator, their are many choices such as www.bigjoshracing.com www.casperselectronics.com and such.
Old Dec 11, 2004
civicvtec1ps's Avatar
Search and Learn
Because you put testpipe in, Obviously cat convert isn't there anymore.
Get O2 sim.
Old Dec 11, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
caspers electronics is junk and it not supposed to work on testpipe. I have it and it don't work. I call them up and they said is supposely work for real high flow cat not test pipe or no cat.
Old Dec 11, 2004
streetglower's Avatar
the check engine light will come on with not having o2 sensors connected and it will come on if you have no cat. Megan racing is just a downpipe with resonator. You can get a o2 simulator which will shut the light off, but your o2 sensor will not be sending info to the ECU about exhaust temp and oxygen levels to optimize air/fuel ratio. Basically your car will be running on inputs from the ECU instead of inputs from the o2 sensor to the ECU. The ECU will decide what is the best air/fuel mixture to throw in. Best bet would be to get rid of that and go back to stock or get a real cat converter.
Old Dec 11, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well the o2 sensors like to turn on around 60 miles after you reset the ecu if everything is working
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
