Sponsored by:
Sponsored by: CARiD
LED Power Window Button *Pics*
Old Nov 17, 2003
abmerop18's Avatar
Jam out with your clam out.
well, i finally decided to try putting some LEDs in the car to replace the stock bulbs. i started with the power window switch that lights up "AUTO". At first i used 3 resistors and i couldnt even see any light, then i tried two and it was too green and not blue, then one and it was also too gree, and i finally used no resistors and it came out a perfect blue. now that i know how easy that it is to do this, i plan on replacing all the rest of the bulbs i have condoms on and putting some LEDs in there. Here is a picture of the blue LED in place. let me know what you think.
Old Nov 17, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Good job. I used no resistors on mine either.
Old Nov 17, 2003
abmerop18's Avatar
did you do the center console too? did you use any resistors on that?
Old Nov 17, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
alright because i cant make out that picture, can you please tell me what you are talking about???? I am currently taking a physics class and we just learned about resistors in my class. What i learned about resistors were that they were needed to slow down current to allow more power to be build up around curvatures. However for some odd reason i dont understand what you are speaking about when you talk about resistors can you please explain
Old Nov 17, 2003
abmerop18's Avatar
you know the switch for the drivers side power window? you know how it lights up a color for the AUTO? well, i replaced the bulb for that that made the "AUTO" light up orange with an LED that lit up blue. i was using resistors because this LED is designed to be used under conditions of 3.7v, whereas the car delivers between 12-14v and the resistors were supposed to reduce the voltage to the LED. i later found out that since the previous orange bulb in there was an LED there already was a resistor built into the chip and that is why i didnt need any of the ones i used. do you understand this?
Old Nov 17, 2003
Novaz3's Avatar
i understand a little better now, so what you are saying is that you are now able to change all the led lights including the ones behind the dash blue???? by using LEDS????? hey can you change the air conditioner leds also??? hey once you complete this task please tell me which lights work the best i dont want to burn out my circuits
Old Nov 17, 2003
abmerop18's Avatar
you can chance every single bulb including the ones behind the gauges and center console. there is a DIY for it somewhere. if you follow it correctly you wont burn any circuits.
Old Nov 17, 2003
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Nice job. Good color choice.
Old Nov 17, 2003
ImPulse's Avatar
u need to have resistors on the center dash... The center dash has little bulbs (i dont think they were LEDs), I dont remember :P anyways, check my ride, there is a link under the description to the DIY
Old Nov 17, 2003
ImPulse's Avatar
http://www.k-series.com/tech_detail...._CON_LITE_SWAP
Old Nov 18, 2003
twizzx's Avatar
twizzx is an unknown quantity at this point
Looks good but did you shave the led? You get a better light disperal that way.
Old Nov 18, 2003
Drnknmnky13's Avatar
Novaz...are you failing that class?
Old Nov 18, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Where did you get the LED's?
Old Nov 18, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
you can buy LEDs at a radio shack near you. www.radioshack.com, You've got questions, They've got answers (R)
Old Nov 18, 2003
That looks sweet! Good job man. So you just replaced the stock led with blue one?
Old Nov 18, 2003
ImPulse's Avatar
From What i remember the lights behind the dash arent LEDs... They are just regular bulbs? I really dont remember but, They unscrew along with there housing, and I just put Blue LEDs in its place...
No, I didnt shave the LED... Im goin to be opening it this saturday and changing the blue to white Like, Jaykuai's Ride!
Old Nov 18, 2003
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
man i want to do this so bad too but with green, but i don't know how to change the bulbs to led
Old Nov 18, 2003
Connie's Avatar
sweetness
Old Nov 19, 2003
GideoN's Avatar
So basically, you can go buy the led's of your choice, remove the stock bulbs and plug the led's in the OEM bulb's place?
Just curious. I've been wanting mine lights white forever.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
