2008 Power Mirror Problem
Old Nov 25, 2010
All Ahead Flank's Avatar
All Ahead Flank is an unknown quantity at this point
My driver's side power mirror isn't working. Are there two fuses for the mirrors, one for the left and one for the right? If so, can someone please tell me which fuse is for the driver's side (left) mirror?
Thanks!
Old Nov 26, 2010
lazlong's Avatar
Re: 2008 Power Mirror Problem
Look under your dash for the under-dash fuse box. Underside of the lid will tell you which fuse it is. If the fuse is good, check for broken wires inside the rubber elbow in the door hinge area.
Old Nov 27, 2010
Thanks, but my fuse panel doesn't have a cover. I looked in the owner's manual and it does describe the fuses, but the power mirror is not listed.
Old Nov 27, 2010
CraigW's Avatar
The fuse is common to both mirrors. If 1 is working the fuse should be fine. I would try moving the L-R selector back and forth several times while trying to move it with the button and look for any changes. Try gently flexing the harness going to the drivers door while
attempting movement.
btw mirrors fuse is #36 10 amp under dash box.
Old Nov 27, 2010
Thanks. I tried the moving the switch back and forth to no avail. I will try the flexing method tommorrow since the car is not in my possession currently.
I assume that if it begins to work, I will have to somehow get inside this rubber boot housing the harness and find and repair the wire.
Old Nov 27, 2010
CraigW's Avatar
Coupe (on the dash) or Sedan (on the door) ??
Old Nov 27, 2010
It's a sedan (on the door).
Old Nov 28, 2010
CraigW's Avatar
Here is the schematic, let us know what you find, I have a '10 FA1
File Type: pdf
Old Nov 28, 2010
I tried flexing the wires and nothing happened. Thanks for sending the schematic. I'll attempt to troubleshoot.
Old Nov 29, 2010
Do you know how to get the switch panel off the armrest?
Thanks
Old Nov 30, 2010
CraigW's Avatar
www.8thcivic.com
Never had my 8th gens apart, only my 7th gens.
Paul Harsze
May 20, 2015 11:37 AM
usajags84
May 10, 2015 08:11 AM
got2kids
May 9, 2015 06:45 PM
mugenca
Apr 16, 2015 12:15 AM
huyqvu
Dec 12, 2001 02:43 PM
