Clutch loss @ high rpm
Old 10-20-2018
07SI8thgen's Avatar
07SI8thgen is an unknown quantity at this point
Hi i have a 07 civic SI 6speed. I just recently replaced the throwout bearing and now i am lossing my clutch pedal @ and above 4k rpms not allowing me to shift till the rpms come way down. I did bleed the slave but still having this issue. Any help would be great.
Old 10-21-2018
Prelude Owner
GolNat's Avatar
Re: Clutch loss @ high rpm
So the car shifts into gear just fine below 4K but won’t go into gear above 4K?
All fluid levels are good trans and clutch master?
Old 10-22-2018
07SI8thgen's Avatar
Correct.
yes, all fluids are topped off and full
Old 10-22-2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
try adjusting like this:
https://www.8thcivic.com/forums/diy-...ch-adjust.html
i've had good results adjusting CMC rods under dash on other vehicle makes, never had an issue in a honda though. still where i would start as it's FREE to try.
or google "omni cmc clutch master civic si 08 09" if you want a master with more push.
curiously.. does it do it more when hot?
Old 10-22-2018
07SI8thgen's Avatar
i adjusted the CMC and the only time it doesnt lose pressure is when i have the CMC adjusted to where the throwout is sitting on the clutch. Or atleast it feels like it is.
Phoenix LSX
Transmission
11-10-2018 05:30 PM
threeoten
Transmission
12-10-2015 11:08 PM
Michael Durkin
Transmission
09-24-2015 12:35 PM
gszarka
23
02-19-2014 12:31 PM
jwhicks81
04-23-2013 05:00 AM
Quick Reply: Clutch loss @ high rpm
