Multiple CEL codes, help would be appreciated
Old Jul 22, 2018
BlueTrane2028's Avatar
BlueTrane2028 is an unknown quantity at this point
I posted this earlier but I think it went to the wrong part of the forum. Apologies for the duplicate. Anyways...
2006 Civic Hybrid dash lit up like a Christmas tree while wife was driving to work. I had her park it and took her the rest of the way in. The vehicle has the following codes, all at once with no recent history of issues:
81-1 abs control unit malfunction
83-1 ecm pcm relation malfunction
84-1 sensor logic malfunction
85-1 controller area network relation malfunction
87-1 wheel speed sensor power supply malfunction
88-1 wheel slip failure of abs activation time too long
P15a5 motor current sensor circuit malfunction
Im hoping there’s going to be one common thread here that ties it together. Haven’t had a chance to attempt to diagnose directly aside from pulling codes yet, will update with anything additional as I find it.
Old Jul 22, 2018
Re: Multiple CEL codes, help would be appreciated
Erase codes and then see what returns?
Old Jul 23, 2018
P15a5 cleared and stayed clear. The rest came back, 82-1, 86-1 and 89-1 are now showing also. Oddly enough there are no warning lights on and the car drives fine.
Old Jul 23, 2018
rats chewing wiring and causing shorts? could be squirrels
Old Jul 23, 2018
P15A5 is an IMA system code, not ABS.
If you meant 86-01 (not 86-1) that would be an F-CAN code, that's one of the communication networks.
Many of the ABS related codes say to troubleshoot fuel and emissions codes first. (But you said that P15a5 stayed gone for now)
An issue I see now is your list of codes doesn't match the troubleshooting info I am reading, like your code reader isn't showing plausible code numbers.
I see 81-xx and 86-xx in my charts but no 82, 83, 84, 87, 88 or 89 series under ABS.
Maybe it's lumping codes from various other systems all together?
03_EM2
Jun 10, 2018 12:54 PM
Nikg
Jan 16, 2015 10:53 AM
Snakes
Dec 1, 2002 09:33 PM
