Car stopped moving, what is this part?
Rep Power: 0 Car stopped moving, what is this part?
Side view, located on the passenger side between the motor and the firewall on the under side.
Car won't pop into gear and it sprayed a bunch of yellowish/brown gunk everywhere.
2009 Hybrid.
2009 Hybrid.
Re: Car stopped moving, what is this part?
See where the shaft of this axle sheared apart (broke in half)? There was a rubber damper or ring strapped to the shaft there, it trapped water and rusted the steel...
Check the other axle shaft for the same rubber damper problem. If it hasn't been replaced already, consider replacing that axle before it breaks and strands you.
Rep Power: 0 Re: Car stopped moving, what is this part?
Received 1,451 Likes
Rep Power: 339 Re: Car stopped moving, what is this part?
my brain refused to see it as a CV joint... they do shear like this then...
whiteazn
08-11-2017 04:08 PM
Uareabozo
07-19-2012 11:12 PM
ManUtd0018
Legal Questions and the Law
09-02-2005 01:28 PM
Genocide
06-17-2002 10:33 PM
