'09 Transmission/Clutch Issue
Old Apr 16, 2016
TravisField1227's Avatar
TravisField1227 is an unknown quantity at this point
Exclamation '09 Transmission/Clutch Issue
View Youtube video here:
As you can see, I am getting a loud clunk/shimmering when letting my foot off the clutch after shifting. This happens when first starting out, after shifting from first to second, and also from second to third. The higher gears are not affected. This is sporadic (getting more consistent by the day), and it's not as severe every time. The above video captured one if it's worst instances.
Vehicle Details:
09 Civic LX
85,000 miles
5-speed manual
Any and all guidance would be greatly appreciated. Thanks in advance!
Old Apr 17, 2016
mac25's Avatar
Dr Krieger of Modification
Re: '09 Transmission/Clutch Issue
if it is when lifting off the clutch, then the clutch should be fine, because it is doing it's job removing connection to a gear.
This is only a guess but I would suspect internal damage to a gear/synchro.
Especially since 3rd, 4th and 5th function; that only leaves the actual gearing in 1st and 2nd which are isolated from the other shifting functions.
Old Apr 17, 2016
Clutch chatter during period of slippage, RPM isn't matched and slow to let pedal up?
Old Apr 17, 2016
I'm not sure what you mean by RPM isn't matched but yes, I am letting up on the pedal slowly.
OptimisticWay
Jan 3, 2016 07:54 AM
Buttertopwhite
Nov 17, 2015 06:41 PM
Ahboy94
Nov 15, 2015 08:42 PM
Hawleywood
Nov 15, 2015 12:16 AM
Kennykenny
Electrical
Oct 31, 2015 02:36 PM
