Clutch not disengaging. Still air in the line??
Old Dec 29, 2015
si-Lover's Avatar
si-Lover is an unknown quantity at this point
I recently had a stage 2 clutch put in my 07 si and when I picked it up from the garage, they told me that they were not completely happy with the clutch pedal. He said he had bled it a lot and it still sometimes does not want to disengage. With how cheap they installed the clutch, I wasn't completely upset, figured it just needed more bleeding or something. I myself have bled it several times and it just keeps acting up. Yesterday I got in it, double pumped the pedal, started it up and it was shifting fine and not trying to pull. I held the clutch in for over five minutes checking the shifting during this time frame and it was good the whole time. I then put it in neutral, let the clutch out, pushed it in like normal and again it was hard to shift. This makes me think it is air and not a cmc or csc leaking by. I do not see any leaks coming from either cylinder, and if you pump it, it seems to disengage completely. Any help or ideas here would be very much appreciated. I don't mind putting new parts in it, but if the cylinders aren't the issue I don't want to spend that money.
Old Dec 29, 2015
Re: Clutch not disengaging. Still air in the line??
It's trapped air, those are a PITA to get bled out completely.
Try pressure bleed, vacuum bleed, speed bleed, reverse bleed.
Search the forum for other threads discussing this problem?
Old Dec 29, 2015
si-Lover's Avatar
Thanks ezone, I really felt that way but after you go through the process 3 or 4 times, you start doubting yourself. As an update, I just got done bleeding one more time and I think I finally got it!! It is shifting really nice, hopefully it lasts and I can move on. I appreciate the response.
burnyd
ECU Fried
May 24, 2018 10:44 PM
krazykoncepts
Sep 8, 2015 09:02 PM
CdnRD
Aug 21, 2015 11:42 PM
Aznnp77
Bolt-on Engine Performance
17
Jan 9, 2004 01:12 AM
aZnVoYCe
Nov 4, 2001 10:18 AM
