Possible Transmission Problem
Old Apr 4, 2015
MattSnypes's Avatar
MattSnypes is an unknown quantity at this point
I have a manual '06 LX Civic with 210k miles. Recently, there has been a whirring sound whenever the clutch is disengaged. The sound is most noticeable in first gear and gets quieter as I go up in gears, with 5 being the quietest. The sound is noticeable with neutral engaged as well. If I push the clutch in, the sound stops. Take the clutch out and the sound starts up again. What could this be and how could I check without taking my car apart first?
Some more useful information:
  • The clutch was replaced about 10k miles ago
  • I think the sound started before the clutch was changed, although it was quieter.
  • The engine sounds fine when revved when the clutch is engaged.
Lastly, if it is the transmission, where can buy a new transmission, or at least a very lightly used one? I can do the change myself.
Thank you for the help.
Old Apr 5, 2015
Re: Possible Transmission Problem
Probably input shaft bearing(s).
Old Apr 6, 2015
dariusld's Avatar
dariusld is an unknown quantity at this point
Is that part of the clutch or transmission?
Old Apr 7, 2015
Inside the trans, on the input shaft.
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
