Speedometer Error
Old Nov 27, 2012
mjohn3's Avatar
mjohn3 is an unknown quantity at this point
Speedometer Error
2005 Civic LX - 5sp manual
Speedometer erratic. Works approx 50% of the time. Or does not return to zero - may stop at 30 or 50mph indicated. Must rely on GPS for speed. Is it the VSS or the cluster itself?
Old Nov 27, 2012
Re: Speedometer Error
Connect a scanner to the diagnostic port.
Check codes. P0500 or P0501 in there?
No.
Display engine data.
Drive the car, see if the VSS indicated on the scanner matches actual road speed.
If it shows actual road speed on a scanner and it looks correct, then you probably have a gauge problem.
Crazygrlinak
Oct 8, 2015 05:06 PM
brash99
Sep 29, 2015 08:42 AM
260000milesgoal
Sep 25, 2015 07:41 PM
jerry38
Sep 20, 2015 08:38 AM
MamaBear2015
Sep 15, 2015 09:35 PM
