Radio/clock powerless
Old Oct 19, 2019
dad3192's Avatar
dad3192 is an unknown quantity at this point
I have a 2001 civic. About a month ago the radio/clock lost all power. I tested my alternator, found it was overcharging (18-19 amps). I checked the fuses and both look good.... any other suggestions? Is there an in-line fuse behind the radio??
Old Oct 19, 2019
Colin42's Avatar
Re: Radio/clock powerless
The alternator may have blown something, get that replaced ASAP. Used junkyard is better than a new parts store one. It can eventually fry the ecu. Aftermarket stereo? Did you connect the orange illumination wire that you're not supposed to?
Old Oct 19, 2019
dad3192's Avatar
Scrap yard alternator in. Radio is bare bones stock. I’ll double check fuses
Old Oct 21, 2019
CraigW's Avatar
Find the fuse called "backup" 12V, constant power items.
Old Oct 28, 2019
dad3192's Avatar
Thanks for the direction.... I have checked every fuse under the dash and hood, and none are burnt out.... my key reminder doesn’t chime when I put the key in. Not sure if that’s connected at all
Old Oct 28, 2019
Colin42's Avatar
If you look through the wiring diagrams you can see what fuse that circuit is on and double check that fuae
Old Oct 29, 2019
BrotatoChip's Avatar
Super Moderator
You can also pull the radio out and start checking for power, ground, and ignition in the connector. That will tell you what's missing and where to start looking.
Old Oct 29, 2019
CraigW's Avatar
Yes, Check Fuse #9 Called Back Up 10A, in Under Hood Fuse Box
bob95065
Electronics
Nov 19, 2022 02:11 PM
Mikalraps
Sep 15, 2018 09:49 AM
WillEl1.7
Oct 21, 2015 09:53 PM
Aw614
Aug 27, 2008 09:37 PM
