footwell LEDs need help
Old 10-09-2013
nir
nir's Avatar
nir is an unknown quantity at this point
hi guyz
i wanna install footwell lights in my 2005 civic coupe.
i searched everywhere on internet but cudn't find anything so i m asking u guys for help.
i wanna connect to dome light and to the parking lights as well.
but i cant find the connectors??
i need to know which connectors and the color of the wire.
plzzz help..
thank u
Old 10-09-2013
CraigW's Avatar
Re: footwell LEDs need help
Dome can be had under the column covers for the key cylinder light used in EX. Wiring should be present on LX.....
DX ??
Tying the 2 separate circuits together.....your on your own.
Old 10-09-2013
Diodes.
Old 10-09-2013
CraigW's Avatar
Originally Posted by ezone
Diodes.
1N4007 is your friend.
Old 10-09-2013
Old 10-09-2013
Prelude Owner
GolNat's Avatar
Might have to use a relay for the dome light. Not sure how much current the footwell lights will pull. Shouldn't be much if they are true LED.
Parking lights are no problem.
Old 10-10-2013
CraigW's Avatar
Relay coils and the PWM used by the dome circuit are not a good mix.
Old 10-10-2013
nir
nir's Avatar
guys i need the dome light wiring diagram or the color of the wire and the connector???
Old 10-10-2013
Prelude Owner
GolNat's Avatar
If you put a diode across the coil it will act as a suppressor to prevent it from energizing/un energizing. Also a cap could be used to help maintain the voltage.
nir: As for wire colors, I don't know. My service manuals for 01-03.
Do you have a multimeter? You can use it to find the wire that you need.
Old 10-10-2013
CraigW's Avatar
Under column covers, wiring for key light = WHT/BLU (+12 volts) & WHT/BLK (grounding side)
Old 10-10-2013
nir
nir's Avatar
Well I guess I'll buy some led strip from eBay or auto store.
I've looked on utube someone has posted a video but it was on
09 civic. I have 05 civic so it's not the same wiring.
Has anyone done this on 05 civic??
Old 10-11-2013
CraigW's Avatar
Yes, I did on my 05. Made my own lighted key cylinder setup, and tapped off of it to run an extra light for the back seat mounted into rear of console.
frank_kleng
09-29-2015 10:55 PM
MamaBear2015
09-24-2015 11:34 AM
Klame9420
09-18-2015 12:37 PM
Jrosa
09-14-2015 08:24 PM
Quick Reply: footwell LEDs need help
