Do I need a relay?
Old 03-07-2012
Fate's Avatar
Fate is an unknown quantity at this point
Do I need a relay?
I am running a few things to a switch panel that is below the radio in my civic. I will have a switch for all these: ignition, starter(momentary), fog lights, and led lights in the car, all on the switch. Will I need relays for any of these? What are relays for? I heard that the switches can get hot and catch fire?
Thanks
Old 03-07-2012
Stock 99's Avatar
Re: Do I need a relay?
The electrical system of your car runs on 12 volts however individual systems work at different amperages. So if your switch is rated for the amperage then you don't need a relay. If you want to run a switch that is not rated for the amperage load then you have to put a relay in between the switch and the load circuit. The relay handles the amperage and the switch triggers the relay.
Old 03-07-2012
Fate's Avatar
Thank you! You wouldn't happen to know the amperage on the ignition would you?
Old 03-07-2012
Stock 99's Avatar
Your fuses will tell you the amperages.
Name:	Civic1999 - Power Distribution.jpg
ID:	82699   Click image for larger version
Name:	Civic2000 - Power Distribution - pt2.jpg
jammer48
10-04-2018 10:04 PM
h4ldol
04-24-2017 08:16 PM
Deebo12
Air Conditioning
09-26-2015 11:08 PM
pilebuck13
09-21-2015 10:45 PM
Juanb24
09-15-2015 12:39 AM
Quick Reply: Do I need a relay?
