How to wire front door speakers?
Old Mar 12, 2012
mason dixon's Avatar
mason dixon is an unknown quantity at this point
I am planning on using an amp to power some front door speakers for a 1998 civic LX.
Has anyone done this or seen a tutorial going through the process?
Do most ppl just drill through the door or go through existing wiring?
Old Mar 12, 2012
513EM1's Avatar
Naturally Aspirated
513EM1 is an unknown quantity at this point
Re: How to wire front door speakers?
No need to drill through the door. Get yourself a spool of speaker wire, connect it to the existing wiring in your doors that are going to your speakers now. Then run your new wire from your speaker, to where ever your amp is located. Same thing for the other side.
Old Mar 12, 2012
I haven't checked but are you sure the 6th gen civics are not using molex connectors? If they are, they would have to be drilled?
Old Mar 12, 2012
513EM1's Avatar
Naturally Aspirated
Honestly, Im not sure. I have a 6th gen, and all 6 speakers in my car are wired to an amp. I did no drilling anywhere.
Old Mar 12, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
If you already have a wiring harness, just connect to the speaker inputs there. If not, just tap into the wires under the dash or behind the kick panels. Unless you are doing a competition system, the stock wiring is more than adequate for your needs.
Old Mar 12, 2012
No competition here, just want to put some infinity 6.5's in, 55w rms....that little stock wiring will handle that?
Old Mar 12, 2012
513EM1's Avatar
Naturally Aspirated
Yes, your stock wiring will work just fine with those speakers.
Old Mar 13, 2012
TiggerDX's Avatar
If it helps, I am running a set of Boston Pro's 6.5" components ran off an Alpine PDX-4.100 bridged at 200 watts a channel with no issues on the stock wiring.
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
Hondasport01
Dec 6, 2001 11:58 AM
doublins
Nov 11, 2001 07:01 PM
