can someone give me the correct answer plz..
Old Jul 5, 2010
charrie01's Avatar
charrie01 is an unknown quantity at this point
hello guys im having problem in my car stereo in my honda civic due to i buy the car without car stereo anyway then i did connect new vstereo on it..now the question is can someone tell me which color will go to the wire tru the stereo i did make the speaker work and the stereo anyway but when i turn off the power of the car the stereo reset and need to change setting on it all over again ..did i miz something to connect like there loads of color code in the stereo but my car wire has 4 like black/red yellow/red white /red black..can someone give me the correct wire diagram of the car wire tru my car stereo..
Old Jul 5, 2010
magicsound69's Avatar
magicsound69 is an unknown quantity at this point
Re: can someone give me the correct answer plz..
the best and fastes way to fix it is to take a test light and with the key on the off position look for the wire that gives u 12 volt and hook that up to the yellow of after market radio that would be ur memory wire then with the key on acc position look for the wire that give u 12 volt woth key on acc but cut off when u take the key out and hook that wire up to the red of after market radio and that is ur switch wire and u should b good to go. try it out and let me know.pezzz
Old Jul 5, 2010
the colors of ur aftermarket radio harness will not match in color to ur wires on the car
Old Jul 11, 2010
charrie01's Avatar
thnx...did get the 12v wire already and -wire or ground wire...now the question is? in my stereo wire ther is much more wired color rather than my car wire.my car wire has 4 included 12v/ground/so the two other wire left i have no clue where to connect it to my stereo wire....my stereo wire has 12v / groumd / acc / ill / mute / system remote which should i connect it? like 12v to 12v wire.ground wire to black wire or can u send me diagram to connect it properly...thnx for the help
Old Jul 11, 2010
charrie01's Avatar
true the wire color r different to my stereo wire...any idea wire code for the honda civic? and which wire will go to stereo wire to my car wire thnx realy...
Old Jul 12, 2010
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
If you did cut the harness go to the12volt.com click on car wiring diagrams find your car click audio and see the wire codes. This saves me from when people cut the wiring harness off "face palm"
Old Jul 12, 2010
sup_mario's Avatar
sup_mario is an unknown quantity at this point
I have the same question too. i need to know some infos. Thanks in advance.
Old Jul 13, 2010
charrie01's Avatar
thnx a lot for the help i didnt cut the wire its just already cut when i both it.anyway i have the car wire code already but i have no clue which it will go.the only thing i know to connect is the 12v and the ground...the rest i have no clue..my stereo wire has 12v /ground /Ill /acc /system remote / this is color coded too...my car wire has 12v / ground / illuminate / switch can u tell me where acc,ill and system remote will be connected from stereo to my car wire.thnx
BootyDo
Jun 21, 2016 03:45 PM
EliseKStewart
Jul 15, 2015 11:11 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
cgavin1
Jul 7, 2015 07:10 AM
