Amp keeps turning on and off after about 15 minutes.
Old Jul 14, 2010
FourBanger95's Avatar
FourBanger95 is an unknown quantity at this point
i have a 300 watt amp with a 100 watt bazooka sub. the gain and boost are turned down. wiring is all good otherwise it wouldnt work for the first 15 minutes. should i invest into a capacitor? would i be safe getting a used capacitor? thanks
Old Jul 14, 2010
Mr.VTEC's Avatar
Mr.VTEC has a spectacular aura aboutMr.VTEC has a spectacular aura about
Re: Amp keeps turning on and off after about 15 minutes.
Is it going into protect mode or just turning off completely?
I had an amp that did this for a while.....at first it was getting moisture inside of it and putting it into protect mode.
Then it did it again but it was turning completly off.....turned out to be a ad ground....my ground was tight and everything....and on a good metal surface...but it just wasnt cutting it...so I relocated the ground and it worked fine from then on out.
Old Jul 14, 2010
Mr.VTEC's Avatar
could also be something heat sync related......just like the xbox 360 RROD! lol
Old Jul 15, 2010
well before when my gain on my amp was about halfway it would turn off then turn back on right away and id hear the sub turning on and off, now that my gain is really low it just turns off for about 30 seconds then turns back on, then about 5 minuts later the same thing. thanks ill move my ground
Old Jul 15, 2010
Mr.VTEC's Avatar
no problem man! let me know if it works or not.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jc33312
May 12, 2015 03:17 PM
jetcare101
May 8, 2015 01:33 PM
WLakers
May 4, 2015 06:23 PM
SpdRcrChk
Dec 22, 2001 02:44 PM
