Are Capacitors Outdated?
Old Apr 27, 2009
Retell's Avatar
Retell is an unknown quantity at this point
I keep hearing that people no longer use capacitors to prevent light dimming? Is this true? What are people using instead (Yellowtop Ultima Battery, higher amp alternators)?
Old Apr 27, 2009
Re: Are Capacitors Outdated?
yeah its really a useless fix. if you have dimming, a cap wont solve the problem like an upgraded alternator will. a bigger battery wont fix it either, it will just take longer to drain. optima is crap btw.
Old Apr 27, 2009
Retell's Avatar
Will a higher amp alternator put more strain on an engine? Would I notice a difference going from a stock 70amp to a 90amp?
I would love your recommendations on both an alternator and a battery for my system.
Old Apr 27, 2009
a little yeah, but that small of an amp rating increase i doubt you will notice. 70 amp is a baby and 90 amp is normal. for a battery, stick with the proven lead acid battery. try and find the 500cca group51 kinds, or just goto the dealer and get it. stock battery is 420cca i believe. i have an autocraft titanium 500cca battery and love it. just check the electrolyte level every month and add distilled water if the levels are low. it should last you a long time.
Old Apr 27, 2009
Retell's Avatar
Thanks for the battery specs to look for, my alternator is stock at 70amps, how many amps would you guestimate I would need?
Old Apr 28, 2009
electric130's Avatar
if you're going to spend the money on a HO alt, get a 130A or so. alter start has them for 7th gens. or it might be a 140A.
Old Apr 28, 2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
anything availible for 7th gens that produce 165-170A? i'd like to deacate the stock 70 to the car and the 100 to the subs.
Old Apr 30, 2009
Retell's Avatar
That is interesting, I never thought about two alternators. Is that a plausible thing to do?
Old Apr 30, 2009
i think he meant 1 alternator that put out 170A. that way, 70A avail for stock operations and 100A excess for audio.
Old Apr 30, 2009
Retell's Avatar
Ahh, I wish someone on here was looking to sell a >100amp alt.
Old Apr 30, 2009
170A output:
http://storesense1.mysuperpageshosti...ail.bok?no=663
Old Apr 30, 2009
Retell's Avatar
A bit more $ than I can afford, I was looking for around $100-150. That is a cool site though. I think I really only need 135Amps
Old Apr 30, 2009
i doubt you can get a stock one for that low!
Old Apr 30, 2009
Retell's Avatar
I have found a rebuilt 120A for $115 shipped on ebay from http://myworld.ebay.com/eagleautoele...:X:RTQ:US:1181
Old Apr 30, 2009
Retell's Avatar
I am going to buy that 120Amp, going from my stock 70A will I need to change my stock wiring to a thicker guage?
Old Apr 30, 2009
most likely yes. the factory wire is only 8-10 gauge i believe which is tiny.
Old Apr 30, 2009
the alterstart's come with new cable, but yes, you'd want to go with at least a 4ga, if not a 2ga cable from the new HO alt.
and no way i'm buying a rebuilt part from some ebay dude. only way i'd buy something rebuilt was from a local supplier that came with a warranty.
Old Apr 30, 2009
Retell's Avatar
Hey has a very large amount of sales with near perfect rating. It comes with a 1 year warranty and I can exchange it if it is not the correct model.
nguyen949
Oct 2, 2003 02:26 AM
kalipnoi
Aug 31, 2003 12:45 AM
jkim1978
Aug 29, 2003 09:17 PM
Civic2001LX
Apr 27, 2003 11:42 PM
noahnoah
24
Jul 21, 2002 06:47 AM
