splitting the power of an AMP to two speakers
1 Post
Rep Power: 328 splitting the power of an AMP to two speakers
just a though, and i needa know what happens.
pretend i have a (mono) 1 channel amp that outputs 100w
if i connect two small subwoofers (or speakers for that matter) in parallel connected to that mono channel amp,
how would the power (or wattage) be divided?
would each woofer get 50w (hypothetical)
is this unsafe or any reason?
reason for asking:
i have a spare 2ch amp that supports 2x75w
i also have 4 bass shakers that are 50w each. i want to connect the bass shakers to that spare amp. each channel would support 2 shakers.
is it doable?
reason for asking:
is it doable?
Rep Power: 294 Re: splitting the power of an AMP to two speakers
Is the amp bridgeable? Are the bass shakers SVC or DVC? What ohms are the bass shakers? Gotta know all that before we move on.
Rep Power: 267 Re: splitting the power of an AMP to two speakers
yes, you're right on the math. you just have to watch the impedance and whether you connect them in series or parallel depending on if the amp can handle 2ohms or not. most amps are 2 ohms stable if they're decent. if the shakers are 4 ohm each, then connect them in parallel. they'll get ~75w each, and then just turn the gain down so they don't distort. if the amp cannot handle 2 ohm, then connect them in series. they will get 37.5w each. if the shakers are 8 ohm, then you should be good with parallel, but they'll still only get 37.5w each due to the impedance being double.
Rep Power: 205 Re: splitting the power of an AMP to two speakers
Yes, sleepy they can be done, but each sub, if wired to match the amp, will get, at RMS, 37.5. If things don't match up correctly, you are looking at around 20W RMS. Do you have the part numbers for the speakers and amp, I'll give you the actualy RMS and tell you whether you should just get a new amp. Also, make sure that the amp has the hpf/lpf you need depending on what you want it for. I'm selling my 4x75W Pioneer soon if you are interested.
NoobyKid
07-13-2015 07:53 AM
Bill in San Jos
07-10-2015 12:32 PM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
