Horn / Stop Fuse...
Horn quit, found the blown fuse which also prevents the Stop lights from working. Replaced the fuse and it blew immediately, is there an easy way to find the short in the system?
Re: Horn / Stop Fuse...
Any aftermarket parts equipped to the car? and if not, since the tail lights don't move and are positioned inside the car, I would check the wires around the horn. Also try to remember when the horn stopped work as you be able to remember what you have done to the circuit. just keep the fuse rating the same, it is written on the fuse panel cover.
check the actual horn (under the bumper near the washer fluid tank), it must have a good ground connection to the car body for it to function properly.
The wiring to the horn itself would only have voltage present when using the horn. I'm guessing the brake circuit or a line with constant power at least.
Use a bulb in place of the fuse... It will glow bright as long as the short is present. Locate and repair the short and the bulb will go out or very dim and the fuse can then be replaced.
18
Aug 17, 2015 08:02 AM
DerbyDad03
Jul 27, 2015 11:34 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
