Notices
Wheels and Tires Post your wheel and tire related questions here.
Rear Brake noise
Old Feb 25, 2010
sparkywilliams's Avatar
sparkywilliams is an unknown quantity at this point
Rear Brake noise
Hi guys im hoping you can help me with this fault.
I bought a secondhand civic 1.4 X reg which has been well serviced but ever since having it ive always noticed a noise from the rear brakes,like a grating noise.I assumed it was the pads rubbing against some corrosion on the discs and and that it would sort itself out but instead its got worse to the point i stall the car when reversing! When i realised the rear offside disc was extremelt hot i thought i should sort it.
I took off both rear wheels and have familiarised myself with the bits but i would like to know what i should do first.
Haynes manual has been ordered.
Thanks in advance
Old Feb 27, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: Rear Brake noise
Stuck caliper?
Old Mar 15, 2010
sdeberry's Avatar
sdeberry is an unknown quantity at this point
I had a similar issue on my '06, the rear pads wouldn't fully release from the disc. Disc got hot, pads were worn unevenly, etc. I thought it was a frozen caliper at first, but after looking at everything, I found that the slides for the calipers needed to be lubed as well as the metal pieces that the pads slide on. The metal pieces that the pads contact should be either replaced or cleaned really well and then lubed with brake grease. Mine were so corroded with build up they wouldn't allow the pads to return to their resting position after being compressed. This is a way cheaper fix than having to replace a caliper, if you can compress the caliper, it's not frozen.
Old Apr 7, 2010
tattooedfreak's Avatar
tattooedfreak is an unknown quantity at this point
Sticking caliper or inside of the rubber brake hose at the caliper is deteriorated and frayed inside not letting fluid by properly
Old Apr 30, 2010
Marilyn's Avatar
Marilyn is an unknown quantity at this point
Okay no problem you have buy second hand car because this problem is common . I think your brakes paddle has worst perhaps you brakes has need brakes oil many this two reason main it cause brakes doing noise you believe me same ditto problem has come in my Audi 6 this problem can be solve easily just you go garage and tell him.
Old Apr 30, 2010
Im stoned off my *** but am I the only one not comprehending this ****? LOL
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Foggy60
May 30, 2015 03:51 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
Andy
Dec 29, 2001 07:32 AM
Sparty
Nov 15, 2001 04:55 PM
