Notices
Wheels and Tires Post your wheel and tire related questions here.
Tire wear problem
Old 04-06-2008
Farging_Icehole's Avatar
Farging_Icehole is an unknown quantity at this point
Cool Tire wear problem
The tires I put on have about 12,000 miles on them over the last 15 or so months. They are not over inflated, but both front tires are completely bald in the middle. The alignment of the vehicle is a little strange sometimes seeming to pull right and others left. Before I take in to shop I wanted to have an idea what I'm looking at if anyone can help. I'd appreciate it.
Old 04-06-2008
Re: Tire wear problem
well did you actually get the car aligned after putting on new tires??
Old 04-06-2008
Ride BMX
Mutha Fn FBM 85's Avatar
what psi are you running exactly? over inflation is the only thing that causes tire wear in the center...
Old 04-15-2008
prsloco's Avatar
prsloco is an unknown quantity at this point
it might be that there is over inflation....or possibly a bad toe problem...if it was camber the wear would b on the side of the tires so it couldnt b that...........u might even have bad caster cuz that would make ur car move to the side.....
Old 04-15-2008
A descendant of 2k1civic.com
pheaton's Avatar
Are the tires OEM size? Have you done anything to the suspension of the car?
Old 04-15-2008
CraigW's Avatar
Have they been rotated since installed ??
Old 05-08-2008
Chopsticks's Avatar
Chopsticks is an unknown quantity at this point
Your right to first think that over inflation was the problem and this is probably wrong but if your tire says max. pressure is 42, you don't fill the tire to max., try 32 or 35 a lower pressure just for the #@^*of it. Pulling different directions can be the road your on unless you drive the same road and always and have the problem? Them I'm perplexed.
Old 05-18-2008
alexb's Avatar
alexb is an unknown quantity at this point
See this website. It's not an inflation problem. There is a techncial bulletin out on this and lots of people complaining.
http://www.houstoncars.org/recall-no...vic-sedans.php
AB
AB
Old 06-26-2008
samshady's Avatar
samshady is an unknown quantity at this point
do any of you guys kno what happens when my tires wear out because of my camber kit? my tech said that the camber wasnt aligned or something and i gotta change my tires even though ive only had it for about a year or so....any suggestions?? thx
Old 06-26-2008
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
i go through a set of all seasons in about a year or 15k miles or so too so it really depends on your driving habit and mods
Old 06-26-2008
well if the wheels arent aligned, they wear out faster.
rhvic
05-22-2015 03:06 PM
Pudnite
05-09-2015 07:51 PM
bo_red
04-23-2015 10:09 PM
supercivic01
South
11-30-2001 11:27 AM
technosilver
11-14-2001 10:58 AM
Quick Reply: Tire wear problem
