1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
control arms
Old Mar 2, 2014
silver-n-black's Avatar
silver-n-black is an unknown quantity at this point
control arms
I'm having to replace my rear lower control arm and I can get a pair of after market ones for the price of an OEM one. My question is all the ones I'm see say that they are adjustable and recommend professional installation wo why is that they look very simple I like to do as much as I can without taking it a shop. Is this something I could do myself
Old Mar 2, 2014
GolNat's Avatar
Prelude Owner
Re: control arms
Aftermarket companies always say professional instal only. That's their CYA statement so that if something fails do to an installation error you can't blame them if you installed it. If a professional did then you can take it up with them.
Old Mar 2, 2014
Re: control arms
so is it something I can do at home. and just get an alignment afterwards. Thanks for your help
Old Mar 2, 2014
Kennykid2002's Avatar
Kenny the Ricer
Re: control arms
Are you replacing LCA, or are you replacing CAMBER arms?
LCA's are not adjustable. You do not need an alignment after a LCA install, but it does require a special socket.
Aftermarket camber arms are adjustable, and do require an alignment afterwards.
They are fairly easy to install, and can be DIY'ed.
However, please don't buy offbrand/no name camber arms, because if they do fail, they can do a bit of damage.
Old Mar 3, 2014
Re: control arms
wasn't the upper control arms adjustable?
I think the lower ones did not have the ball joint moveable.
even with OEM, it's recommendable to align after, your current ones could be bent and aligned with them.
Old Mar 4, 2014
Re: control arms
I'm replacing the LCA not the CHAMBER the bushing is worn out and I don't feel like just putting in new bushings so I just bought a new OEM LCA from a local auto parts store. But now I'm worried cause it looks a little different which is no big deal but the fit just doesn't look right. They had 2 options both without ABS but one was "except Japan built " I don't think it is but how do I find that out
Old Mar 4, 2014
Re: control arms
Your VIN would start with "J" if it was built in Japan.
If it starts with a number 1, 4, or 5 it was built in the USA.
If it starts with a number 2 it was built in Canada.
Old Apr 14, 2014
Re: control arms
I have been looking at why my rear right side has a rattling sound AFTER I have changed my LCA with a stock replacement. The car has had rear disc conversion but have read that I should have got a LCA for an Intgra are these the same parts thanks for any help you can give
Curtchuk
Aug 5, 2015 02:14 PM
brainwashedmc
Jul 27, 2015 10:05 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
