1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
camber kits
Old Dec 13, 2009
koisser6284's Avatar
koisser6284 is an unknown quantity at this point
camber kits
i just instaled a drop kit on my 95 dx coupe , Eibach Sportline spring with Tokico HP shock and all strut brace , i don't know why but the rear is lower than the front ??? when i went to the alignement shop , the tech guy said i needed a camber kit , will that fix my problem ??? and there so many kit and and so many brand ... what will you recommend me !!!
Old Dec 14, 2009
Re: camber kits
SPC makes a good camber kit, ive had mine for a long time, several yrs at least and its fine. as far as the drop height, it depends on the springs and shocks. do you have heavy stuff in the rear (subs, junk, etc)? the car does need a week or two to settle properly on new suspension, but i doubt it will change much. did you get the right springs for your car? coupe and sedan are usually not the same parts. otherwise you could get a different spring for the rear, maybe the prokit which is a smaller drop than sportline. and adjusting alignment will not affect ride height, it will only straighten the wheel direction.
Old Dec 19, 2009
Re: camber kits
yes i have 2 10'' subs but is not that heavy and yes i have the right kit for my car , but it's ok is not that bad , a B16A2 is in my mine so the extra weight will probably level it , thank you very much for your help !!!
Old Feb 16, 2010
Re: camber kits
yes i have 2 10'' subs but is not that heavy and yes i have the right kit for my car , but it's ok is not that bad , a B16A2 is in my mind so the extra weight will probably level it , thank you very much for your help !!!
Old Mar 27, 2010
Re: camber kits
i heard SKUNK2 is good and cheep , what do you think ???
Old Apr 1, 2010
DANNY213's Avatar
DANNY213 is an unknown quantity at this point
Re: camber kits
i kinda got the same problem...I got some Skunk2 sport shocks and Blox competition lowering springs for my 95 coupe and the rear is higher than the front. The mech. told me that i needed to get some shorter springs for the rear so they can be the same height,as well as getting a camber kit.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
