vss help, need quick answer!
Rep Power: 0 vss help, need quick answer!
So my speedometer and odometer are not working, thought it was the gauge cluster. So I bought a used one for 20 dollars, this one also does not work.
we tested the vss with an ohm meter, and the resistance is way lower than chilton's says is should be.
So Im going to purchase a new speed sensor, Here is my question; Will a vss from a civic work with my gsr tranny? or do I need to buy a gsr speed sensor?
I can save a lot of money if the civic one will work.
thanks.
thanks.
Rep Power: 208 Re: vss help, need quick answer!
lol triz
but i dont think it will
simply because B series parts are not interchangable with D series.
try junk yards where you can pocket the vss for free!!!
h4ldol
04-24-2017 08:16 PM
Bricoleur
09-09-2015 06:48 PM
