1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
87 doesnt start
Old Feb 13, 2008
dreamer87's Avatar
dreamer87 is an unknown quantity at this point
87 doesnt start
i need help
i have an 87 DX 5 spd. 116,000 its been sitting around for like 7 yrs and the alt. is rusted out.. doesnt move. belt broke. i think its got an oil leak. it turns over fine, but it just doesnt want to go. i tryed to roll start too. i pulled plugs to see if spark.. i dont see much. coil needs replacing? distributer? new plugs/wires? how much? i dont know if compression is any good. i can smell gas from carb. and i lost the bolts to the alt. anyone know where i can find new ones?
not a 'for sale' thread.. but im tired of messing with it, i paid 700 . its in Maine, with rust. offers anyone?
Old Feb 17, 2008
MultiCRX's Avatar
MultiCRX is an unknown quantity at this point
Re: 87 doesnt start
I would think it might be a fuel issue if it's been sitting around that long. I'm working on an Accord right now that hasn't been cranked in about 2yrs. Fuel is all gunked up. Can't hear fuel pump come on when the key is turned. If your's is fuel injected, make sure the fuel pump is working.
The igniter in the distributor was also bad. You should be able to pull one of the plugs out and hold it (Ground it) to the block safely somewhere and have someone else turn over the engine to see if you have spark. Then if you have spark, a small whiff of starting fluid in the air intake should tell you something. If it hits a few times, then it wants to run.....it's just a fuel issue.
Hope that helps,
Ed
Old Feb 17, 2008
Re: 87 doesnt start
if it turns over, you can do a compression test no?
Old Mar 18, 2008
dreamer87's Avatar
Re: 87 doesnt start
~ no, my 87 is carburated.
thats some helpful info, when i get it towed to my friends house, i'll drain the tank/fuel system. then give it some carb cleaner.
i also tryed the spark plug trick, barely any blue spark. not sure if its cuz i dont have a working altenator (battery gets low) or if my coil pack needs replacing...
~ i dont have the compression tools to check. and i dont have money, yet. working on getting lisence back.
~ i still dont know where to find altenator bolts. i need info on that. anybody parting out theres? hard to find model, thats why i want to keep it.
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
